Dome Siren secondary sound with Node-Red
Trying to get the dome Siren to use its secondary chime using node-red without success
I have the Siren working fine using node-red but cannot get the parameters working correctly to switch it…
Anyone have any example flows with theirs?
Sure here is the import for node red
        "id": "12ebf7d6.f64958",
        "type": "server-state-changed",
        "z": "7c4440d.fcc82c",
        "name": "Any Window Opened",
        "server": "8a745406.799e98",
        "version": 1,
        "entityidfilter": "_window",
        "entityidfiltertype": "substring",
        "outputinitially": false,
        "state_type": "str",
        "haltifstate": "on",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "outputs": 2,
        "output_only_on_state_change": true,
        "x": 820,
        "y": 660,
        "wires": [
                "c3864e1c.a207b"
        "id": "c3864e1c.a207b",
        "type": "delay",
        "name": "",
        "pauseType": "rate",
        "timeout": "5",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "2",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": true,
        "x": 1040,
        "y": 660,
        "wires": [
                "cfb5963d.e0d948"
        "id": "cfb5963d.e0d948",
        "type": "api-call-service",
        "name": "Do a chime",
        "version": 1,
        "debugenabled": false,
        "service_domain": "zwave",
        "service": "set_node_value",
        "entityId": "",
        "data": "{\"node_id\":51,\"value\":4,\"value_id\":\"72057594899972097\"}",
        "dataType": "json",
        "mergecontext": "",
        "output_location": "",
        "output_location_type": "none",
        "mustacheAltTags": false,
        "x": 1250,
        "y": 660,
        "wires": [
        "id": "8a745406.799e98",
        "type": "server",
        "z": "",
        "name": "Skynet Home Assistant - Local",
        "legacy": false,
        "hassio": true,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": true
I get this… when I change your node_id value to mine (8)
    "node_id": 8,
    "value": 4,
    "value_id": "72057594899972097"
“Call-service API error. Error Message: 72057594899972097”
Ah its cause you need to have unique value id. Here is a post on how to set that up: Support for Z-Wave Sirens/Chimes
