Dome Siren works only once Scripting issue
Prior to the 2022.2 (2022.2: Let's start streamlining! - Home Assistant) release the Dome Siren would not work at all due to the bug found in the z-wave integration. Now it works … err … once then fails every time there after.
Executed: February 20, 2022, 10:45:14 AM
Error: ‘type’
Failed to call service “type”
If change a pram slightly and re-save I can run the script again, but if I try to run again it fails again.
So the fix in the previous release works … err… sort of.
Thoughts?
