I updated module readme here.
YES! Thank you!
After adding the port number I can control the lights.
Are shutters (DTRV01) supported?
Also, I defined a dimmer but it doesnât work.
It appears as a switch (not a slider) in the overview page.
under the âlightâ group I have:
- type: DMR
module: 8B3
channel: 1
Is this correct? How do you set it up?
Good to know.
I have no DTRV01 in my installation so I have never tested it. So officially itâs not supported.
For a dimmer to work you need to use type: DIM like here:
light:
- type: DIM
module: 8B3
channel: 1
Type DMR is for DMR01 relay module
Type DIM is for DDIM01 dimmer module
Than you, changing to DIM solved this.
HI,
iv been trying to install the has_domintell on a Debian with venv (if it matters) with no luckâŠ
I keep getting ERROR (MainThread) [homeassistant.setup] Setup failed for domintell: Integration not found.
can you please advice?
I followed the instruction from https://github.com/shamanenas/has_domintell but probably Iâm missing somethingâŠ
TIA
I had a network problem and resetting the switch solved an issue where domintell devices didnât always respond to commands.
It would be a nice if the integration will verify that sent commands have been performed.
Hi Shamanenas
I am new to HA !
I would like to modify, add DALI module to python domintell but I canât find or HA to install .py files
Can you help me ?
Thanks in advance
Joseph
Hi Yaccri, Did you test the DTRV01 integration ? Did you find a way to make it works ?
Hi Shamamenas,
Very nice work ! congratulation !
Do you think you can implement control for DTRV01 ?
I have the driver element that i put in attachment coming from iridium, it can maybe help ?
Frédéric
Yes, it works fine.
Iâm not sure whether the author added it to the distribution.
great ! can you show me an example of config for dtrv01 ?
refards
frédéric
cover:
- platform: domintell
devices:- type: TRV
module: 117D
channel: 1
- type: TRV
Thank you yaccri, working perfectly ! but where did you find the information ? for example cover: ?
Frédéric
The âcoverâ section is where shutters are defined in HA.
âTRVâ is a type-name that is defined within the domintell plugin
Hi Shamanenas, do you think it would be possible to add support for module DTRP02 in cover ? today it support DTRP01 only. i see that in the python bib that you use DTRP02 is supported.
Also , any plan to support the new master DGQ04 ?
Best regards,
Frédéric
Hi did anyone tried using serial connection to domintell?
I have only DETH03 and disconnected DETH04 modules no DETH02.
Should I just connect with cable to main unit (Idk component name, but old one I think DGQ01?) ? And how will I initialize serial connection from homeassistant?
Thank you so much for your help.
I will try to get it working tomorrow, so any help is good, thanks
First off all big thanks for all your work
I implemented the most modules.
The only thing i couldnât add where
- the temperature sensors on the touchscreens [TSB]
- and the longpress on the BU2 and BU4
- the touch buttons on the LCD screens [PBL]
are thes things possible?
I would also be interested for support of DGQG04, seems Websockets need to be used instead of UDP
Hello I followed the procedure on Github, but I canât make the integration work. I always get the message :[547785412176] The system cannot restart because the configuration is not valid: Platform error light.domintell - Integration âdomintellâ not found. Integration error: domintell - Integration âdomintellâ not found.
My configuration.yaml:
and the path:
What am I doing wrong?
The day after: my first button suddenly worked. However the button does not remeber its position.
