Domotz API and REST
Hi i m’ in trouble using domotz api and rest , if some one could help me it was welcome !
api extract a json like this :
“id”: 3154932,
“display_name”: “Nvidia Shield”,
“protocol”: “IP”,
“snmp_status”: “NOT_FOUND”,
“user_data”: {
“name”: “Nvidia Shield”
“first_seen_on”: “2019-02-06T21:49:06+00:00”,
“importance”: “FLOATING”,
“type”: {
“detected_id”: 114,
“id”: 29,
“label”: “Media Player”
“details”: {
“zone”: “RDC”,
“room”: “Salon”,
“firmware_version”: null,
“serial”: null,
“notes”: null,
“snmp_read_community”: “public”,
“snmp_write_community”: “private”
“os”: {
“name”: “android”,
“version”: null,
“build”: null
“ip_addresses”: [
“192.168.x.xxx”
“last_status_change”: “2025-01-08T21:03:55+00:00”,
“status”: “DOWN”,
“vendor”: “NVIDIA”,
“grace_period”: 120,
“model”: “SHIELD TV Pro”,
“agent_reachable”: true,
“open_ports”: {
“tcp”: [
                       "udp":  [
    "hw_address":  "00:04:4B:86:E4:F4",
    "names":  {
                  "host":  "NvidiaShield.lan",
                  "bonjour":  "SHIELD-Android-TV-xxx",
                  "upnp":  "SHIELD",
                  "netbios":  "SHIELD",
                  "zeroconf":  "Android"
    "is_jammed":  false
i have a rest config in my configuration file with working count of ONLINE and inventory device :
`rest:
  • resource: https://api-eu-west-1-cell-1.domotz.com/public-api/v1/agent/xxxxxx/device
    method: GET
    headers:
    Accept: application/json
    X-Api-Key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    scan_interval: 300 # Intervalle de mise à jour en secondes
    Sensor Ok
    • name: Domotz Devices Inventory
      value_template: ‘{{ value_json | length }}’
      json_attributes:
      • devices
    Sensor Ok
    • name: Domotz Devices Online
      value_template: >
      {{ value_json | selectattr(‘status’, ‘equalto’, ‘ONLINE’) | list | length }}
      json_attributes_path: “$.”
      json_attributes:
      • devices`
My problems is when i want to create a card to list ONline devices , i can’t found how to do
Hello fau,
This seems to not be Home assistant related. Are you in the right forum?
Don’t fall into the Streetlight Effect.
yes yes it 's i want to connect my home assitant with domotz via the api .
in relation with this subject : Flex-table-card - #269 by WattsAmps
but i need help as i have some trouble , it’s partialy working :slight_smile:
i have found the way to have it work finaly thanks to CLAUDE !
'command_line:
  - sensor:
      unique_id: domotz_raw
      command: >
        curl -s -X GET
        "https://api-eu-west-1-cell-1.domotz.com/public-api/v1/agent/xxxxxxx/device"
        -H "Accept: application/json"
        -H "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx_apikey"
        | jq -c '{devices: .}'
      value_template: "{{ value_json.devices | length }}"
      json_attributes:
        - devices
      scan_interval: 300
and a tempates sensors :
- name: Domotz Total
      unique_id: domotz_total
      state: "{{ state_attr('sensor.domotz_raw', 'devices') | length }}"
      icon: mdi:lan
    - name: Domotz Online Count
      unique_id: domotz_online_count
      state: >
           | selectattr('status', 'equalto', 'ONLINE') | list | length }}
      icon: mdi:lan-check
    - name: Domotz Down Count
      unique_id: domotz_down_count
      state: >
           | selectattr('status', 'equalto', 'DOWN') | list | length }}
      icon: mdi:lan-disconnect
    - name: Domotz Online List
      unique_id: domotz_online_list
      state: >
           | selectattr('status', 'equalto', 'ONLINE') | list | length }} appareils
      attributes:
        devices: >
             | map(attribute='display_name') | sort | list }}
      icon: mdi:lan-check
    - name: Domotz Down List
      unique_id: domotz_down_list
      state: >
           | selectattr('status', 'equalto', 'DOWN') | list | length }} appareils
      attributes:
        devices: >
        vital_down: >
             | selectattr('importance', 'equalto', 'VITAL')
