Donetick : a user friendly task and chore management addon
Donetick is a task and chore management tool that allows you to schedule recurring chores and easily track their completion. For each task, you can assign multiple people who can perform it, and you can choose how the assignee is selected (randomly, least completed, last completed, etc.). I built Donetick as an alternative to the wonderful Grocy, but with a different and modern UI, and a total focus on tasks and chores with more features
I’ve been using Donetick myself for a while and found it very helpful for me, so I decided to open-source it, and make it self-hostable, and I even created a Home Assistant add-on to make it easier to get started.
to check all the features please check Donetick website
Here is a summary :
  • Group-based task management: Create and manage tasks solo or with your family.
  • Rotation and assignment: Assign tasks to individuals with rotation strategies like random or least completed.
  • One-Sentence Task Creation: Create tasks by simply describing them in a sentence. Donetick will extract dates, times, and recurrence patterns from your natural language.“Take the trash out every Monday and Tuesday at 6:15 pm” will automatically generate the correct task.
  • Points System: You can assign different points to different tasks and users gain points once they complete the tasks
  • Task Filtering & Search: If you can filter tasks by due date, assignee, etc.
  • Things Integration: Use entities (numbers, strings, booleans) to trigger tasks, track values, or connect with external systems via webhooks.
  • Webhooks: You can configure Donetick to send all events to home assistant and have different automation triggers such as notifications, events including task completion, reminders,etc…
  • Homeassistant Integrations: You can manage the tasks from home assistant using the custom component without going through Donetick app
  • Homeassistant Addons: Of course, you can selfhost Donetick by clicking the button below
Open your Home Assistant instance and show the add add-on repository dialog with a specific repository URL pre-filled.
  1. This is a personal project and I do not have plans for major updates or improvements in the near future I have been spending too much time on improving which has turned into a time sink. I’ll eventually start spending less time on it at some point. However, I would be very glad to receive contributions and review PRs. Please let me know before starting a contribution to make sure it aligns with the goals of the project.
Task View
History View:
Task/Chore View
Activities Overview
Points Overview
Reserved for Future
This has so much potential, but I think you will find limited use from Home Assistant users in its current guise. The add-on appears to be just the self hosted product wrapped, with no integration in to Home Assistant. Another interface to look for the task list. Sorry - that isn’t something I personally would be interested in. Home Assistant is my interface, you need to interface with that.
The first thing I went for is rubbish collection, but rubbish collection is hard. Different bins on different days, changes for public holidays etc. Plus I have that information in HA already.
What you need to do is create a proper integration, which works either with the add on or your hosted version. This integration at a basic level needs to do three things which I think will make it very popular very quickly.
  1. Get the bin information out of Home Assistant.
    This integration does the work for you: GitHub - mampfes/hacs_waste_collection_schedule: Home Assistant integration framework for (garbage collection) schedules
    Config Flow for your integration can ask for the bin information created by that integration.
  2. Have a way for the state of entries to be reflected in Home Assistant. Probably something along the lines of due, do (a user specified time before the due date /time) or, done. Then we can use conditional cards to show buttons and reminders. I don’t think people will mind initially going in to the app interface to set that, but you need to make it part of the HA integration long term.
  3. Have Home Assistant able to update the task, so when I press the button generated by the state of a task in Do, it is changed to Done and then the scheduler resets the state to Due.
    For bins, you will probably want a second task of “Bring the bins in”, which is generated the by same data, possibly created or enabled by the first task being marked as done.
This will save a lot of work where people are creating text entries changed by buttons etc.
You should then have a way for HA to create tasks/chores.
In the future, have the users in HA used as the users in your tool - so that a task assigned to me, only displays on my phone, but a task assigned to my wife shows on hers.
As a personal project, well done, it looks good. But you need full HA integration otherwise it is just another tool which is ignored because it requires going in to another interface.
Hi @scriven33 !
I appreciate you taking the time and provide this feedback! am definitely open to having integration similar to what Grocy has currently seems what you describing!
While my immediate focus is on the core features of Donetick, integrating with Home Assistant is definitely on my mind once Donetick is in a later stage!
As you pointed out, mampfes’ project is fantastic for handling trash collection. Donetick, on the other hand, was built to address a slightly different set of needs.
I will share why I built this maybe to give an idea of why am not tracking things inside home assistant( I was initially as dates as you see below
first, the history retention need is a little bit different. I want the history to stay indefinitely for things like AC filters, water filters, etc. Also I want to have an optional note for example when I do some maintenance and replace a part I want it to record it somewhere that I don’t lose
also, I want to be able to assign different people to different chores and want to ability to have a rotation. and a way they do it now even if they don’t have the app by scanning NFC tag to take them to the page and no need to click anything and the task will be marked as completed.
I don’t think everyone needs/ benefits from using Donetick but for those who do I think should provide a good value!
Please let me know if you have any other feedback after using it!
How can we help with the translation?
This looks like a good self hosted alternative to Tody or Sweepy. But when I install I get the error message:
“This add-on is not compatible with the processor of your device or the operating system you have installed on your device.”
I’m running the latest HA on a Raspberry pi 4, (which I thought was the most common hardware), is it really incompatible with a pi4, or am I missing something?
@furtado Thank you! Hopefull will have this started soon and can use help with translation soon!
@95beer I published a new version that should have support for armv7. if you run into any issues please feel free to let me know here add support for armv7 · Issue #6 · donetick/donetick · GitHub ! Let me know if you have other feedback since you were familiar with today and Sweepy!
Thanks for the quick help! The UI looks great, and I like that tasks aren’t forced into “rooms” like other apps, if the task is cleaning aircon filters for example, I don’t need 3 notifications for the 3 rooms, I’d do them all at once. That being said, my first thought for the tags was “Inside” vs “Outside”; it would be better if the tags were remembered and auto given different colours. And if I click on the tag in a task, it brings up all the tasks with that tag.
I have 5 messenging apps on my phone, and none of them are Telegram, so I don’t really want a new app just for notifications. Best case would be using the HA To-do list integration (which can also have due dates/times shown), so the list can be on my wall tablet dashboard all the time.
Small things; list of “Things” is shown white in dark mode (not that I use this function), it’d be good to have a checkbox in the add-on to turn off the “create new users” button, I think the “due today” filter should also include overdue tasks, and I think the default view when you open the app should more clearly separate future tasks from stuff due today and overdue (just a line or space maybe).
Thanks @95beer ! I released a new version with a new label manager. While the UX still needs some work, it’s functional. We’ve also added shared labels across tasks!
I wasn’t aware of the Todo List integration, but thanks for the tip! I’ve created a beta version. It currently provides a read-only view of your Todoist tasks in Home Assistant. I expect to have it fully installable in the next few days via HACS. once some Home Assistant requirements are met.
Looks cool, but How do I open the Web UI?
http://my_home_assistant_comain.com:2021/ just gives me ERR_CONNECTION_TIMED_OUT
If I try the local version http://10.0.24.2:2021/ it gives me just a white page, but it has some relevant HTML.
<!doctype html>
<html lang="en">
  <head>
    <meta charset="UTF-8" />
    <!-- <link rel="icon" type="image/svg+xml" href="/logo.svg" /> -->
    <meta name="viewport" content="width=device-width, initial-scale=1.0" />
    <!-- <title>FE Template</title> -->
    <link rel="apple-touch-icon" sizes="180x180" href="/apple-touch-icon.png" />
    <link rel="icon" type="image/png" sizes="32x32" href="/favicon-32x32.png" />
    <link rel="icon" type="image/png" sizes="16x16" href="/favicon-16x16.png" />
    <link rel="mask-icon" href="/safari-pinned-tab.svg" color="#5bbad5" />
    <meta name="msapplication-TileColor" content="#da532c" />
    <meta name="theme-color" content="#ffffff" />
    <script type="module" crossorigin src="/assets/index-ox7w3lh5.js"></script>
    <link rel="stylesheet" crossorigin href="/assets/index-BOnJsUaH.css">
  <link rel="manifest" href="/manifest.webmanifest"></head>
  <body>
    <div id="root"></div>
  </body>
</html>
A little update:
I tried installing on UnRAID/docker and got the same issue.
After some days I just checked and both the home-assistant donetick ui worked and the unraid one.
I guess it just needed some time to get ready.
Hey @meauxt ! Thanks for what looks like a great project. I have been using Grocy solely for chores for about two years (I think) and it has really helped get things done around the house. What I like about my current setup is that I am able to use Home Assistant for the daily notifications of chores via mobile messages and also automations if chores are not done (send a TTS announcement to the kids on their smart speakers before lights out). The Grocy card is also used to mark these chores off within HA.
What I don’t like about Grocy for chore tracking? I have Grocy in Docker and for unknown reasons it is often near the top of my usage monitor. This thing really just hangs out for my needs but yet uses a good bit of resources. Short of that, I couldn’t find a way to implement a vacation/holiday mode so that certain days could be skipped. We end up with a ton of chores to do when coming back from breaks.
Can you tell me if there is a way to pull Donetick data into HA? Any plans for a card similar to Grocy? Would really like to give this a go but would like to make the switch as transparent to the family if possible.
Again, thanks for making all this available! I’ve got a side project going and I know it takes a lot of effort so yours is most appreciated!
@flemmingss Glad your issue is resolved! let me know if you run into other issues!
Apologies as I somehow missed the post above with the link to the thing I was requesting! Looks like I’ll have to give it a try. I did see that it is read only. Are you opposed to adding a way to interact from HA for marking these off or am I misunderstanding?
@dinki My apologies for the delayed response! You’re right, the integration is read-only for now. I have plans to add more features, but my focus has to be on Donetick’s core functionality at the moment. If anyone in the community is interested in contributing to the integration, that would be fantastic! Otherwise, I’ll do my best to get to it when I have more availability!
Nah no apologies needed. I really should have read a bit closer.
I can totally understand, and relate, to the need to focus efforts especially if your dev time is limited or you have other pressing issues to spend your time on.
I’m looking for a drop in replacement for what I have now so the ability to mark tasks done within HA is a must. My family looks at me sideways if I ask them to install another app :slight_smile: Will keep an eye on this project for sure.
I tried to install this, seems to install but nothing opens in the WebUI. Just me?
Hi @HackerJL !
Please share the logs and more details and i will be happy to assist! feel free to open an issue on github with the details!
Hey @meauxt !
Thank you so much for your work on this project. This is exactly the type of solution I’ve been looking for. Looking forward to seeing it evolve.
Hey, keen on this, seems to do mostly everything I need. I agree with @dinki about the HA integration. Unfortunately I am hopeless with this stuff or I would help where I can.
What my wife keeps on asking for is a snapshot on the HA home screen in a calendar format so she knows which child has to do what, then the kids can click the button when done :slight_smile:
@bjm make a great integration like this might be out of my league, but I’m keeping my fingers crossed that someone will be able to integrate this well, similar to how great the Grocy integration was. I’d gladly help with any backend work needed to get there!
@BSkando Thank you! glad you find it helpful!
