Hi all, I have bought some Aqara door and windows sensor P2 that works with matter over thread just to try them because I have a zigbee dongle-E that is compatible with this standard.
I follow some instructions on the web and I change the firmware of my dongle by putting a multipan RCP firmware that allows to use both zigbee and matter over thread.
Then I see that to use both I need another software level and so I added the multipan container in my docker compose configuration. This is my configuration:
version: '3.9'
services:
home-assistant:
container_name: home-assistant
image: ghcr.io/home-assistant/home-assistant:latest
volumes:
- /home/lab/homeassistant:/config
- /run/dbus:/run/dbus:ro
devices:
- /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221130193241-if00:/dev/ttyACM0
environment:
- TZ=Europe/Rome
network_mode: host
restart: always
matter:
container_name: matter
image: ghcr.io/home-assistant-libs/python-matter-server:stable
restart: unless-stopped
network_mode: host
security_opt:
- apparmor=unconfined
volumes:
- /home/lab/matter:/data
multipan:
container_name: multipan
image: b2un0/silabs-multipan-docker
cap_add:
- SYS_ADMIN
- NET_ADMIN
restart: always
privileged: true
network_mode: host
devices:
- /dev/ttyACM0
volumes:
- ./data/:/data
environment:
# OCPD environment variables
DEVICE: "/dev/ttyACM0"
BAUDRATE: "460800"
CPCD_TRACE: "false"
FLOW_CONTROL: "false"
NETWORK_DEVICES: 0
# OTBR-AGENT environment variables
OTBR_ENABLE: 1
BACKBONE_IF: "wlp1s0"
OTBR_LOG_LEVEL: "debug"
OTB_FIREWALL: 1
OTBR_REST_LISTEN_PORT: "8081"
# OTBR-WEB environment variables
OTBR_WEB_PORT: "8086"
# SOCAT environment variables
NETWORK_DEVICE: ""
# ZIGBEED environment variables
EZSP_LISTEN_PORT: "9999"
# UNIVERSAL FLASHER variables
AUTOFLASH_FIRMWARE: 0
FIRMWARE: "86"
influxdb:
image: influxdb
container_name: influxdb
restart: always
ports:
- '8086:8086'
environment:
- TZ=Europe/Rome
volumes:
- influxdb_data:/var/lib/influxdb2
appdaemon:
build:
context: .
dockerfile: Dockerfile
container_name: appdaemon
volumes:
- /home/lab/appdaemon:/conf
ports:
- 5050:5050
- 12345:12345
environment:
- TZ=Europe/Rome
restart: always
volumes:
influxdb_data: {}
I also added the matter container but I don’t understand if I really need it, what I’m seeing on internet is confusing me.
I also see that if I want to use ZHA i have to use this configuration:
socket: //core-silabs-multiprotocol:9999
but when I try to set this configuration HA says me that is impossible to connect.
