Don't run a flow if it was run in the last 2 minutes
I’m creating a flow to record from a camera if there is motion when no one is home.
However, the motion detector goes on and off a bit and I don’t want it to start a new recording each time. Is there a way to stop the flow from running if it has run in the last couple of minutes?
A trigger node could assist you with this. Have it send the signal to start then set your “wait period”, then send nothing or the latest msg object.
Brilliant, thanks. This works.
