Doods - "Error while processing state changed"
I have Doods configured but when it’s called by my automation or even when I call it directly from the “developer tools” I get this error in the logs
Logger: homeassistant.helpers.event
Source: helpers/condition.py:232
First occurred: 1:45:00 PM (3 occurrences)
Last logged: 1:46:01 PM
Error while processing state changed for image_processing.doods_camera_solarium
  File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 257, in _async_state_change_dispatcher
    hass.async_run_hass_job(job, event)
  File "/usr/src/homeassistant/homeassistant/core.py", line 433, in async_run_hass_job
    hassjob.target(*args)
  File "/usr/src/homeassistant/homeassistant/components/homeassistant/triggers/numeric_state.py", line 130, in state_automation_listener
    matching = check_numeric_state(entity_id, from_s, to_s)
  File "/usr/src/homeassistant/homeassistant/components/homeassistant/triggers/numeric_state.py", line 99, in check_numeric_state
    return condition.async_numeric_state(
  File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 232, in async_numeric_state
    fvalue = float(value)
TypeError: float() argument must be a string or a number, not 'dict'
Here is my configuration
- platform: doods
  url: "http://192.168.XX.XX:8080"
  detector: default
  scan_interval: 10000
  source:
    - entity_id: camera.camera_solarium
  file_out:
    - "/config/www/cameras/{{ camera_entity.split('.')[1] }}_latest.jpg"
    - "/config/www/cameras/{{ camera_entity.split('.')[1] }}_{{ now().strftime('%Y%m%d_%H%M%S') }}.jpg"
  labels:
    - name: dog
      confidence: 50
      area:
        top: 0.2
        right: 0.2
        left: 0.2
        bottom: 0.2
        covers: true
And here is my automation analyzing the results of the image processing and sending me a notification if something matches
alias: Send Notification when motion is detected
description: ''
  - platform: numeric_state
    entity_id: image_processing.doods_camera_solarium
    above: '0'
    attribute: matches
condition: []
  - service: notify.mobile_app_iphone
      message: Motion detected at the back yard
      title: Solarium Motion
        photo:
          - file: /config/www/cameras/camera_solarium_latest.jpg
        caption: Camera Solarium
mode: single
What am I doing wrong?
