Sometimes the motion sensor dowsn’t register someon taking a shower. So i would like to see the following logic.
If door is closed and motion detected - do not switch the light off unless the door is opened again.
But out of ideas here. One way is
Trigger
Door closed
Condition
motion on
But this set up has a drawback that even under normal conditions when you leave and close the door behind you - same conditions will apply, never switching the light off
You could use an input_bookeN to keep track of presence. Switch it on when the door is opened the first time and switch it off when someone leaves a second time.
Well that means an ideal scenario that everybody closes the door behind him. I think it will not be a case…
Maybe something like if door was closed and motion detected for at least 2 minutes - set the presence boolean to on. And than a rule that if boolean is set to on and door opened - set it to off.
This boolean will be in coditions for the lights off rule… Looks like it might work but still looking for ideas
