Door bell being trigger multiple times
Hi guys,
Wondering, my current doorbell work like a charm however I believe at the moment it will create an error when someone presses the bell more than once. I there a way to make it so that once press it will trigger the automation but not multiple actions within a certain time period before it can be triggered again?
automation:
  - alias: Notification Doorbell activated
    description: Notification doorbell being pushed
      - platform: state
        entity_id: switch.sonoff_1000ca0c17
        to: 'on'
      - service: camera.snapshot
          entity_id: camera.front_garage_cam
          filename: '/config/www/tmp/snapshot_garage.jpg'
Add a condition-
  - condition: template
    value_template: >-
      {{ (as_timestamp(now())-as_timestamp(state_attr('automation.notification_doorbell_activated', 'last_triggered') | default(0)) | int > 5) }}
Change 5 (in second) to the desired value.
Or even simpler:
automation:
      - platform: state
        to: 'on'
      - delay:
          seconds: 6    # change this to the time you want between activations
mode: single            # only run one instance of this automation
max_exceeded: silent    # don't log errors if attempting to run more than one instance
Also I moved your post as this is about configuration of home assistant. The development topic is for questions about developing new integrations and such.
