Door lock(ed) MQTT sensor
I wanted a door lock sensor so that i can see if the door is locked. Our door has three bolts and two of them come out of the door and hook into the frame:
This is known as a ‘driepuntssluiting’ in the netherlands.
I wanted to make use of the fact that the hook moves downwards when the door is locked.
I placed two combined dip switches in the frame and connected them to a low power MySensors compatible switch node.
Parts i used:
I glued together two switches and added a small plastic plate to the levers. I placed them inside the frame like this:
The switch node is placed on the inside of the frame like this:
I connected the node to my MySensors gateway and if the state of the lock chenges, a MQTT message is sent to Mosquitto and it’s picked up from thre by Home assistant.
The node runs a couple of weeks now and it’s pretty stable. It works very reliable.
hey there
any chance you could share some photos of your state card and your configuration
Sorry, missed this one…
Configuration is simple:
- platform: mqtt
  state_topic: 'mysensors-out/78/1/1/0/3'
  payload_on: "1"
  payload_off: "0"
Card is even simpeler:
Quick question - why TWO sensors glued together?
These microswitches are really narrow (5.7mm) and two together makes the chance that they are correctly pressed, bigger.
