Hi I’m trying to make a custom button card that has 3 states based off of 2 input boolean and one tap action
States:
Locked, This state is lock bolt engaged
input_boolean.test_open_closed = closed
input_boolean.test_locked_unlocked = locked
Unlocked, This state is lock bolt disengaged
input_boolean.test_locked_unlocked = unlocked
Open, Lock disengaged and open
input_boolean.test_open_closed = open
How is the best way to achieve this? can I use custom button card?
The situation is when you have a hardwired door lock or door lock controller that integrates to Home Assistant via I/O like esphome.
eg Relay 1 = Lock / Unlock control
Input 1 = Bolt position
Input 2 = Reed switch (door position)
I had this code for lock and unlock But I don’t know how to bring in the 2nd state of door open closed.
show_name: true
show_icon: true
type: custom:button-card
entity: input_boolean.test_open_closed
state:
- value: 'on'
color: green
icon: mdi:door-open
styles:
icon:
- filter: opacity(100%)
- animation: blink 2s ease infinite
- value: 'off'
color: red
icon: mdi:door-closed
tap_action:
action: toggle
service: null
confirmation:
text: Confirm Unlock?
entity: button.garage_door
