alias: '[Badkamer]Deur open: Verwarming uit'
description: ''
- platform: state
entity_id: binary_sensor.badkamerdeur
to: 'on'
for: '0:05:00'
- platform: state
entity_id: climate.badkamer
attribute: hvac_action
to: heating
condition:
- condition: state
state: 'on'
for: '05:00'
- condition: state
state: heating
- condition: time
after: '06:30'
before: '23:59'
- service: script.turn_off_badkamer_heating
- device_id: 621869ba5dd715a0989efa6d994c05e3
domain: mobile_app
type: notify
message: Verwarming uitgezet
title: Badkamerdeur staat open en de verwarming stond aan.
mode: single
But for some reason it never fires. To verify; the bathroom door (badkamerdeur) is left open quite often, so it should fire quite often when it tries to heat, right?
Manually firing it does work, so the script it’s calling is fine.
description: ''
- platform: state
to: 'on'
for: '0:05:00'
- platform: state
to: heating
condition:
- condition: state
state: 'on'
- condition: time
after: '06:30'
before: '23:59'
domain: mobile_app
type: notify
mode: single
Could it be that the bathroom door has been open for HOURS already, and not 5 min?
EDIT: Not sure how, but i had the TADO smart app still setup for a smart-heating scheme.It now overwrites that if the heating is on with the same action.
I see you’ve already corrected part of the automation where there is a “for” in a condition. This is not currently possible. Nor is it likely to be due to the data overheads to checking something that happened in the past. And the simple step of checking - last_triggered or last_changed etc. Should suffice (though does require some templating skills).
