This blueprint is set up to watch a binary sensor. When it goes from off to on (closed to open) it triggers a message to be sent to the google enabled speaker of your choice. The message will play after a delay you set and repeat on that same delay until the switch returns to off (closed), at which time it sends a different message. The delay time and all the other parameters are adjustable.
Changelog
2022-05-05: Updated for 2022.5.0 HA. Added Markdown to !input Descriptions.
2022-04-11: Add multiple to Speaker Selection and changed minimum HA to 2022.4.0
2022-01-03: Remove ‘Door’ restriction on input sensor, and expanded description.
2021-12-24: Add pick list of all the available languages and dialects.
2021-10-29: Add the ability to select the time-frame the announcement will be active
2021-09-03: Add Description
2021-06-16: First blueprint version
Needs Home Assistant Core 2021.3 or higher and Nabu-Casa to work
Get Started
Updates will be published on my GIT repository with the rest of my Home Assistant Blueprint collection.
Option 1: My Home Assistant
Click the link below to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Please Click the
at the end of the Post if you find this Useful
Option 2: Direct Link
Copy this link if you want to import the blueprint in your installation.
https://github.com/SirGoodenough/HA_Blueprints/blob/master/Automations/door_open_tts_cloud_say_announcer_nabu_casa_required.yaml
Description
This is a TTS.cloud-say version of another Door Announcer I found in the HA Blueprint Exchange. For people that have Nabu-Casa, TTS.cloud-say is far superior to TTS.google_say as it adds languages and gender to the voices available. If you are a Nabu-Casa subscriber, I highly recommend using this.
You will need to select a country code as listed in the TTS.cloud_say documentation listed here: Cloud TTS
Usage
Installation
Open Home Assistant with administrator privileges and on a Lovelace screen, click anywhere in the main entity area and type the letter ‘c’. A selection box should pop up. Type blue and select the button to navigate to blueprints. You can also find blueprints by selecting configuration from the left menu and then blueprints from the center menu.
Once there, click on the ‘Import Blueprint’ button in the lower right side of the main screen.
In the ‘URL of the blueprint’ line type or paste in the URL of my Blueprint. I have the blueprint stored on my Public GitHub:
To make the blueprint work it will need
• 1 binary_sensor entities to sense the action you are announcing
• 1 media_player, group of media _players, or list of media_players to send the words to
• Pick a gender and language from Cloud TTS
Once you have the entities created or decided upon you can build the Automation. To build the automation:
- Add a Description so you can tell what this one is for
- Use the Drop-downs to select the Entities for the listed purposes
- Set the time-frame that the automation will be active. Default is always on.
- Select the speaker Gender and Language from the Nabu Casa website
- Enter the messages for when it is found open and when it finally closes
- Set the time delay before the first message and between the open messages
Walk-thru:
- The header of the Blueprint contains the required info plus the URL from where it came from.
- The input: section is where it gets the information it needs to fill in the blanks. This information is stored in the actual automation referencing this Blueprint when executing the task.
- The Trigger section will start everything when your Binary Sensor changes state from off to on.
- Once triggered it goes into a repeat loop that starts with the delay time selected. This repeat loop will immediately abort if the binary sensor flips back to off. If the binary sensor stays on long enough to get passed the delay time, the initial announcement will be sent to the speaker and it will cycle back to the top and start the repeat loop again.
- When the binary_sensor flips to off it will play the closing message,
All My Blueprints
Here is a list of each of my blueprints, a quick description and jump links to the Blueprints Exchange post…
Scripts
Broadlink on Script Blueprint
This is a SCRIPT Blueprint that uses my Broadlink RM3 to turn my TV on and get it into the correct mode, Pushes remote buttons in sequence.
Tasmota EZ Button Blueprint
This Script Blueprint generates 3 Buttons to help you manage your Tasmota installed base. Restart All, Update a few, and Update all.
Play Media File Script Blueprint Blueprint
This is a SCRIPT Blueprint. This provides a way to play canned media files with the big long list of YAML entries but keep the main script or automation clean.
TTS All Message Blueprint
This script can use any of the 11 integrated TTS Platforms in Home Assistant to send a message to a media player.
Automations
Auto Fan Control Blueprint
This Blueprint is for controlling a 3 speed fan based on a temperature sensor. Both fan% control & MQTT fan control versions.
Door Open TTS Cloud-Say Message Blueprint
This Blueprint is a TTS.cloud-say version of another Door Announcer I found in the HA Blueprint Exchange.
Keypad Lock or puzzle Box Tool Blueprint
This Blueprint accepts 5 actions & when done in the right order, flips an input_boolean.
Zigbee2MQTT - Xiaomi Cube Controller Blueprint
This Blueprint uses a Zigbee2MQTT built sensor to sort out the multitude of commands from the Xiaomi Magic Cube Remote.
Zigbee2MQTT - ZemiSmart ZM-RM02 Controller Blueprint
This Blueprint uses the Z2M (Zigbee2MQTT) imported Action sensor to sort out the 18 commands from the ZemiSmart ZM-RM02 Controller.
Contact Links or see my other work
What are we Fixing Today Homepage / Website: https://www.WhatAreWeFixing.Today/
Channel Link URL: (WhatAreWeFixingToday) https://bit.ly/WhatAreWeFixingTodaysYT
What are we Fixing Today Facebook page (Sir GoodEnough): WhatAreWeFixingToday
What are we Fixing Today Twitter Account (Sir GoodEnough): https://bit.ly/WhatAreWeFixingTodayTW
Discord Guild: (Sir_Goodenough#9683) WhatAreWeFixingToday?
If you want to support me
Buy me Coffee: Sir GoodEnough
PayPal one-off donation link: PayPal.Me
#WhatAreWeFixingToday
#SirGoodEnough
