Can you someone help me with my problem? I have woox window and door sensor.
Sensor works with tuya app but doesn’t with home assistant. I’m okey with this but…
I’m open the door, sensor turn on some tuya smart plug but the state of this plug doesn’t change in home assistant and this is my problem.
Any idea how to fix this? Thanks
I purchased today the same exact sensor with intention to get notifications when the door opens but also to turn on some smart plugs on or off with some delay. While my sensor will arrive tomorrow, so i can test it, you mention that the status of the plug does not change in Home Assistant.
A few questions:
Have you connected the Tuya / smart life app with home assistant?
Are you able to see the smart plug in Home Assistant?
If you manually turn the smart plug on or off does the change register in Home Assistant?
The automation to turn on the smart plug when you open the door, is built in Home Assistant or in the Tuya app?
Did your door window sensor Tuya integration worked with HA? I recently bought 2 Fengchuang door/ window wifi sensors from Amazon to give it a try. It works with Tuya app and also devices visibile in Tuya cloud but HA Tuya V2 integration does not show these sensors whereas my Tuya bulbs appear & working well. Any idea about door window sensors?
I can see it in Tuya/Smart life app, google assistant recognises it and can give the state when asked, but Home assistant does not pick it up as a sensor. All the other tuya devices work perfectly.
Cannot find any event… But now i have an idea!!! Since the phone receives a notification each time the sensor opens, and the HA app has access to the notifications (i can see the text under states) can we use the last notification as a trigger to an automation?
It would be like if the last notification contains the words Open Notification in title then perform the action assigned to it
With the upgrade to HA 2021.11.1 on my dev setup, my door sensors got picked up automatically by HA. Now I can see all Tuya cloud devices lights & door sensors, still there are other things that I need to fix with this upgrade. Thanks.
