This is my flow:
[{"id":"dd16f012.7bced8","type":"tab","label":"Flur Heizung an","disabled":false,"info":""},{"id":"161e55e6.cd879a","type":"api-call-service","z":"dd16f012.7bced8","name":"","server":"c1af9201.0bc7e","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_on","entityId":"switch.heizung_flur","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":510,"y":460,"wires":[["ec77d123.20f258"]]},{"id":"fcd4d9ae.3b69f8","type":"time-range-switch","z":"dd16f012.7bced8","name":"Tag","lat":"","lon":"","startTime":"06:00","endTime":"20:00","startOffset":0,"endOffset":0,"x":450,"y":320,"wires":[["161e55e6.cd879a"],[]]},{"id":"ec77d123.20f258","type":"api-call-service","z":"dd16f012.7bced8","name":"","server":"c1af9201.0bc7e","version":1,"debugenabled":false,"service_domain":"notify","service":"pushnotify","entityId":"","data":"{\"message\":\"node-red: Heizung Flur eingeschaltet\",\"data\":{\"priority\":-1}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":520,"y":560,"wires":[[]]},{"id":"4952c3d0.1d9bcc","type":"poll-state","z":"dd16f012.7bced8","name":"","server":"9816e521.d65e58","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"updateinterval":"300","updateIntervalUnits":"seconds","outputinitially":false,"outputonchanged":false,"entity_id":"sensor.flur","state_type":"num","halt_if":"19.5","halt_if_type":"num","halt_if_compare":"lte","outputs":2,"x":130,"y":80,"wires":[["368b237d.6a8294"],[]]},{"id":"368b237d.6a8294","type":"api-current-state","z":"dd16f012.7bced8","name":"","server":"9816e521.d65e58","version":1,"outputs":2,"halt_if":"false","halt_if_type":"bool","halt_if_compare":"is","override_topic":false,"entity_id":"switch.heizung_flur","state_type":"habool","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":300,"y":180,"wires":[["fcd4d9ae.3b69f8"],[]]},{"id":"c1af9201.0bc7e","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"9816e521.d65e58","type":"server","name":"Home Assistant","addon":true}]
