Door sensor + Light or Switch + delay off
GitHub Link Click Here
Version: 1.1
A very basic automation for a door sensor (or any binary sensor really) to active a light or a switch which will turn off after a certain delay if the door is left open.
blueprint:
  name: Door Sensor-activated Light/Switch With Delay
  description: >
    Version: 1.1
    Turn on/off a light or a switch when door is opened/closed and off after the door has been opened for a while.
    For community support see this forum post: [Click here](https://community.home-assistant.io/t/door-sensor-light-or-switch-delay-off/483329).
    GitHub: [Click here](https://github.com/maur8ino/home-assistant-blueprints/blob/99e75b7981dedb7d10bbcddbd641ea7298d924c3/automations/door-sensor-turn-on-off-light-or-switch-with-delay.yaml)
  domain: automation
  input:
    door_sensor_entity:
      selector:
        entity:
          domain: binary_sensor
          multiple: false
    light_or_switch_target:
      selector:
          entity:
            domain:
              - light
              - switch
    door_opened_wait:
      description: Time to leave the light/switch on after door is opened
      default: 120
      selector:
        number:
          min: 0.0
          max: 3600.0
          unit_of_measurement: seconds
          mode: slider
          step: 1.0
mode: restart
max_exceeded: silent
  platform: state
  entity_id: !input door_sensor_entity
  to: "on"
  - service: homeassistant.turn_on
    target: !input light_or_switch_target
  - wait_for_trigger:
      - platform: state
        to: "off"
    timeout: !input door_opened_wait
  - service: homeassistant.turn_off
Thanks for geat blueprint.
Is it possible to add run only if statment.
Example:
Run only if dayligt sensor is off or sun below horizon?
/Claes
Hi Claes,
there could be surely done: I designed this blueprint for my specific use case which is a closet that sometimes is left open, but the door closet is the only source of light, so it didn’t make much sense to add a condition there.
Let me think about it!
I’m not sure if this would drop straight into the blueprint between trigger and action (you may want to adjust offsets), but it works for me in my regular automations…
condition:
  - condition: sun
    before: sunrise
    before_offset: "+01:00:00"
    after: sunset
    after_offset: "-02:00:00"
That’s a good blueprint the only i have to add is for change the mode to restart if it is trigger again before ends the time
Just add this at he start of the blueprint
mode: restart
The condition for the sun works good for me
