Last night my door sensor changed state from “false” to “true” for no reason apparently (the door was closed). I am running HA 69.1 on a PI3 with an Aeon Labs Gen5 USB stick. The door sensor I have is an Aeotec ZW120 Door Window Sensor Gen5.
I would reallu appreciate if someone would be able to provide some input or any idea as to why this could happen, and/or how I might prevent it from happening again. This could potentially trigger a false alarm while we’re all sleeping, something which would really not make the wife or the kids happy
At the same time as the state changed, I was editing some config files on the PI via SAMBA, when my editor seemed to hang for a couple of seconds with no response. When it came back alive, the device reported “door opened”. I don’t know if the fact that the PI became unresponsive for a few seconds has to do with a false positive state report from the Z-wave sensor.
By looking at the Z-wave log, I can see that the device reports four almost simultaneous “true” reports. Could this be a sign of a faulty device? I am also thinking that perhaps a factory reset would be worth a try.
Here is the HA log from the time it happened (at about 22:49:26)
2018-05-19 22:48:34 WARNING (MainThread) [homeassistant.components.sensor] Updating hue sensor took longer than the scheduled update interval 0:00:00.500000
2018-05-19 22:49:26 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-19 22:49:27 WARNING (MainThread) [homeassistant.components.sensor] Updating netatmo sensor took longer than the scheduled update interval 0:00:30
2018-05-19 22:49:27 WARNING (MainThread) [homeassistant.components.sensor] Updating hue sensor took longer than the scheduled update interval 0:00:00.500000
2018-05-19 22:49:28 WARNING (MainThread) [homeassistant.components.sensor] Updating hue sensor took longer than the scheduled update interval 0:00:00.500000
2018-05-19 22:49:36 ERROR (SyncWorker_1) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-05-19 22:49:37 ERROR (SyncWorker_1) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-05-19 22:52:02 WARNING (MainThread) [homeassistant.components.sensor] Updating hue sensor took longer than the scheduled update interval 0:00:00.500000
And here is the corresponding Z-wave log (The door sensor is Node012)
2018-05-19 22:48:33.077 Detail, Node012, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x20, 0x01, 0xff, 0x23
2018-05-19 22:49:26.229 Detail,
2018-05-19 22:49:26.229 Info, Node012, Received Basic set from node 12: level=255. Treating it as a Basic report.
2018-05-19 22:49:26.229 Detail, Node012, Refreshed Value: old value=0, new value=255, type=byte
2018-05-19 22:49:26.229 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.229 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.269 Detail, Node012, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x20, 0x01, 0xff, 0x23
2018-05-19 22:49:26.270 Detail,
2018-05-19 22:49:26.270 Info, Node012, Received Basic set from node 12: level=255. Treating it as a Basic report.
2018-05-19 22:49:26.270 Detail, Node012, Refreshed Value: old value=255, new value=255, type=byte
2018-05-19 22:49:26.270 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.270 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.309 Detail, Node012, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x20, 0x01, 0xff, 0x23
2018-05-19 22:49:26.309 Info, Node012, Received Basic set from node 12: level=255. Treating it as a Basic report.
2018-05-19 22:49:26.310 Detail, Node012, Refreshed Value: old value=255, new value=255, type=byte
2018-05-19 22:49:26.310 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.310 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.348 Detail, Node012, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x20, 0x01, 0xff, 0x23
2018-05-19 22:49:26.349 Detail,
2018-05-19 22:49:26.349 Info, Node012, Received Basic set from node 12: level=255. Treating it as a Basic report.
2018-05-19 22:49:26.349 Detail, Node012, Refreshed Value: old value=255, new value=255, type=byte
2018-05-19 22:49:26.349 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.349 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.397 Detail, Node012, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x30, 0x03, 0xff, 0x31
2018-05-19 22:49:26.397 Info, Node012, Received SensorBinary report: Sensor:49 State=On
2018-05-19 22:49:26.397 Detail, Node012, Refreshed Value: old value=false, new value=true, type=bool
2018-05-19 22:49:26.397 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.397 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.439 Detail, Node012, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x30, 0x03, 0xff, 0x31
2018-05-19 22:49:26.439 Info, Node012, Received SensorBinary report: Sensor:49 State=On
2018-05-19 22:49:26.439 Detail, Node012, Refreshed Value: old value=true, new value=true, type=bool
2018-05-19 22:49:26.439 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.439 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.485 Detail, Node012, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x30, 0x03, 0xff, 0x31
2018-05-19 22:49:26.485 Info, Node012, Received SensorBinary report: Sensor:49 State=On
2018-05-19 22:49:26.485 Detail, Node012, Refreshed Value: old value=true, new value=true, type=bool
2018-05-19 22:49:26.485 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.486 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.525 Detail, Node012, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x30, 0x03, 0xff, 0x31
2018-05-19 22:49:26.526 Detail,
2018-05-19 22:49:26.526 Info, Node012, Received SensorBinary report: Sensor:49 State=On
2018-05-19 22:49:26.526 Detail, Node012, Refreshed Value: old value=true, new value=true, type=bool
2018-05-19 22:49:26.526 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.526 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.625 Detail, Node012, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0c, 0x0a, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x16, 0x00, 0x00, 0x76
2018-05-19 22:49:26.626 Detail,
2018-05-19 22:49:26.626 Info, Node012, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:22, status=255
2018-05-19 22:49:26.626 Detail, Node012, Refreshed Value: old value=0, new value=0, type=byte
2018-05-19 22:49:26.626 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.626 Detail, Node012, Refreshed Value: old value=23, new value=22, type=byte
2018-05-19 22:49:26.626 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.690 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.752 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.776 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.820 Detail, Node012, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0c, 0x0a, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x16, 0x00, 0x00, 0x76
2018-05-19 22:49:26.821 Detail,
2018-05-19 22:49:26.821 Info, Node012, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:22, status=255
2018-05-19 22:49:26.821 Detail, Node012, Refreshed Value: old value=0, new value=0, type=byte
2018-05-19 22:49:26.821 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.821 Detail, Node012, Refreshed Value: old value=22, new value=22, type=byte
2018-05-19 22:49:26.821 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.857 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.903 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.941 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:26.994 Detail, Node012, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0c, 0x0a, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x16, 0x00, 0x00, 0x76
2018-05-19 22:49:26.994 Info, Node012, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:22, status=255
2018-05-19 22:49:26.994 Detail, Node012, Refreshed Value: old value=0, new value=0, type=byte
2018-05-19 22:49:26.994 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.995 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:26.995 Detail, Node012, Refreshed Value: old value=22, new value=22, type=byte
2018-05-19 22:49:26.995 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:27.041 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:27.086 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:27.121 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:27.163 Detail, Node012, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0c, 0x0a, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x16, 0x00, 0x00, 0x76
2018-05-19 22:49:27.163 Info, Node012, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:22, status=255
2018-05-19 22:49:27.163 Detail, Node012, Refreshed Value: old value=0, new value=0, type=byte
2018-05-19 22:49:27.163 Detail, Node012, Changes to this value are not verified
2018-05-19 22:49:27.163 Detail, Node012, Refreshed Value: old value=22, new value=22, type=byte
2018-05-19 22:49:27.164 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:27.221 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:27.263 Detail, Node012, Notification: ValueChanged
2018-05-19 22:49:27.318 Detail, Node012, Notification: ValueChanged
2018-05-19 22:51:59.723 Info, Node006, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - False
