I am trying to integrate sensors which I bought prior discovering the wonderful world of zigbee.
It is the case of some Geeni sensors and switches.
I managed to integrate all switches via Tuya and in HA. However it looks that the Geeni SS201 (door window sensor) , though registered in Tuya and visible in home assistant, has no event exposed.
A message unsupported appears when I check in HA the sensor listed in the Tuya devices.
i have the same issue and have the sensors (zigbee) on my garage doors. They work in the Tuya app but not in the HA Tuya or localTuya integrations. In the Tuya IoT cloud i see them but they are sub-devices with no ip. Other motion sensors (zigbee) work fine and fast. I am using the Moes wired hub and Hue bulbs as repeaters and have a strong signal.
Hello me again, I am actually moving all Tuya cloud to Tuya Local and as a matter of face the two door sensors seems to miss the IP. I guess I will need to see if the HostID is registered somehow on the router or on any utility. I am trying to recover it via the mac id of the device
