Door Windows Sensor WADWAZ-1 with ZWAVE-JS
Hi Folks
I just switched from original ZWave to ZWave-JS. Most things seemed to work out following the instructions. I have 3 of these WADWAZ-1 door sensors and 1 works but the other two will only display the battery status. I have up loaded a pic of the two entities the working one and the failing one. I am missing the Temp Door Sensor Basic on the failing one. I have removed the node completely and reboot the system but noting seems to work.
Entities 1
That is fixed in a future version of the Z-Wave JS library. How did you install the z-wave js server, addon or standalone docker?
I installed as add on.
I have the same sensor and the same issue with zwave js installed as an addon. Did anyone figure out a fix or are we waiting for an update to the addon?
Did anyone get this working, I have a lot of these sensors and none of them seem to show open/closed status?
