Based on @AndreiRadchenko’s blueprint found here: 414976
I modified the original blueprint to allow for one of the actions to launch a custom app on your phone. Tested and working on Android.
Quoted/modified info from original:
Blueprint for automation that sends actionable notifications with a photo on doorbell press.
Notifications are sent to home assistant companion app on android or ios.
Automation can be triggered by any entity that changes state from ‘on’ to ‘off’. i.e. switch, motion sensor, input_boolean, binary_sensor can bee chosen as automation trigger.
You can edit notification title . Message is day and time of automation triggering.
Snapshots are stored in config/www/doorbell folder and can bee used with gallery card.
You can specify mobile_app device or group of devices for notification to be sent to.
For iOS yor can chose notification sound from dropdown list, or set you own sound.
There are three action button in notification. The first one opens dashboard view that specified in blueprint. The second one launches the phone app you specify. And the third one performs configurable action2.
You can also set the time during which the actions in the notification are active.
blueprint:
name: Doorbell cam actionable notification with app launcher
description: Blueprint for automation that send actionable notification with photo
on doorbell press. Notification are sending to home assistant companoin app on
android or ios. Automation can triggering by any entity that change state from
<on> to <off>. i.e. switch, motion sensor, input_boolean, binary_sensor can bee
chosen as automation trigger. You can edit notification title . Message is day
and time of automation triggering. Snapshots are stored in <config/www/doorbell>
folder and can bee used with gallery card. You can specify mobile_app device or
group of devices for notification to be sent to. For iOS yor can chose notification
sound from dropdown list. There are three action button in notification. The first
one opens dashboard view that specified in blueprint. Next two buttons perform
configurable action1 and action2. You can set the time during which the actions
domain: automation
input:
notification_title:
name: Notification title (Optional)
description: 'Default: "Someone rang the doorbell!"'
default: Someone rang the doorbell!
doorbell_button:
description: Changing state of this entity fom <off> to <on> will start doorbell
notification automation.
selector:
entity: {}
doorbell_cam:
description: The Camera from wich take photo for notification.
selector:
entity:
domain: camera
multiple: false
notify_dev:
name: Device to notify
description: Device or group of devices for notification through mobile_app
notification service. For example <notify.mobile_app_iphone>, <notify.all_devices>
selector:
text:
type: search
multiline: false
ios_sound:
description: Notification sound for iOS (Optional). Default <US-EN-Morgan-Freeman-Someone-Is-Arriving.wav>
default: US-EN-Morgan-Freeman-Someone-Is-Arriving.wav
selector:
select:
mode: dropdown
custom_value: true
options:
- US-EN-Morgan-Freeman-Someone-Is-Arriving.wav
- US-EN-Morgan-Freeman-Wife-Is-Arriving.wav
- US-EN-Morgan-Freeman-Boss-Is-Arriving.wav
- US-EN-Morgan-Freeman-Girlfriend-Is-Arriving.wav
- US-EN-Morgan-Freeman-Welcome-Home.wav
- US-EN-Morgan-Freeman-Son-Is-Arriving.wav
- US-EN-Morgan-Freeman-Roommate-Is-Arriving.wav
- US-EN-Morgan-Freeman-Motion-Detected.wav
- US-EN-Morgan-Freeman-Motion-In-Wine-Cellar.wav
- US-EN-Morgan-Freeman-Motion-In-Garage.wav
- US-EN-Daisy-Back-Door-Motion.wav
- US-EN-Daisy-Front-Door-Motion.wav
- US-EN-Alexa-Motion-In-Garage.wav
- US-EN-Alexa-Motion-In-Back-Yard.wav
- US-EN-Alexa-Motion-Detected-Generic.wav
multiple: false
uri_:
description: Dashboard tab to open by click <Dashboard> button. Default </lovelace/default_view>
default: /lovelace/default_view
uri2_:
description: Phone app to launch
default: app://replace.with.app.uri
action2_title:
name: Action 2 title (Optional)
description: Action to perform on click action 2 button
default: action2
action2:
description: Action to run on action button 2 press
default: []
selector:
action: {}
delay:
name: Delay (Optional)
description: The time during which the actions in the notification are active
default: '30'
selector:
number:
min: 0.0
max: 120.0
unit_of_measurement: seconds
mode: slider
step: 1.0
source_url: https://community.home-assistant.io/t/doorbell-cam-actionable-notification-with-app-launcher/489144
variables:
button: !input doorbell_button
image_file: /local/doorbell/{{ expand(button)[0].last_changed | as_timestamp |
- entity_id: !input doorbell_button
platform: state
to: 'on'
condition: []
- alias: Set up variables for the actions
variables:
action_2: '{{ ''ACTION_2'' ~ context.id }}'
- data_template:
entity_id: !input doorbell_cam
filename: /config/www/doorbell/{{ expand(button)[0].last_changed | as_timestamp |
service: camera.snapshot
- service: !input notify_dev
title: !input notification_title
message: '{{ as_timestamp(now()) | timestamp_custom(''%d:%m %H:%M'', true) }}'
push:
sound: !input ios_sound
ttl: 0
priority: high
image: '{{ image_file }}'
actions:
- action: URI
title: Dashboard
uri: !input uri_
- action: URI
title: App
uri: !input uri2_
- action: '{{ action_2 }}'
title: !input action2_title
- alias: Wait for a response
wait_for_trigger:
- platform: event
event_type: mobile_app_notification_action
event_data:
timeout: !input delay
continue_on_timeout: true
- alias: Perform the action
choose:
- conditions:
- condition: template
value_template: '{{ wait.trigger.event.data.action == action_2 }}'
sequence: !input action2
