For a coople of weeks, I search about a doorbel.
Here some needed characteristics:
- SIP support: The doorbell act as a phone, it can establish a phone call, if you the right code on the keeboard you can open the door.
- ONVIF, RTSP
- RTSP
- POE
Here is an resume of my research:
Hikvision DS-HD1 3MP
IP65
2048 x 1536 Resolution at 30 fps
compatible avec carillon mécanique
soud dual way
NO SIP compatibility !!!
Mechanic chime compatible
speaker
alimentation: 16 a 24V AC
Home assistant driver
data sheet: https://us.hikvision.com/sites/default/files/data_sheet/ac_ds-hd1_111519na_0.pdf
Comments: network connection not stable
Prix: 130$ US
Axis A8105-E
1920 x 1200 Resolution Video at 50 fps
180° Panoramic Field of View
SIP support
Digital PTZ
ONVIF Profile S compliant
Event triggers Analytics, External input, Edge storage events
Call: DTMF, State, State changes
Detectors: Audio detection, Live stream accessed, Shock
detection
Hardware: Temperature, Tilt detection, Network
Input Signal: Digital Input Port, Manual trigger, Virtual inputs
Storage: Disruption, Recording
System: System ready
Time: Recurrence, Use schedule
1 relay
POE
data sheet: https://www.axis.com/files/datasheet/ds_a8105e_t10069545_en_1910.pdf
home assistant driver
Prix: $619.95
Linovision/Dahua/OEM VTO2101E-P-S1
1/2.7" 2MP CMOS
Zinc alloy panel, IP65,IK10
TCP/IP,SIP
IP65
DC 12V, PoE(802.3af)
2 relais
data sheet: https://www.allnet-italia.it/sito/ItemsDownloads/ART-127462.pdf
Prix: $374.00
Doorbird D101
POE
SIP
15VDC
IP65
720P
HTTP, HTTPS, SSL/TLS, Bonjour, DNS,
RTSP, RTP, TCP, UDP, RTCP, ICMP, DHCP,
ARP, SIP, DTMF (RTP [RFC-2833], SIP
INFO [RFC-2976]), STM
data sheet: https://www.doorbird.com/downloads/datasheet_d101_en.pdf
Prix: 394 $US
Beward DS06MP
SIP, ONVIF ,VOIP ,RTSP
ethernet
controler needed !!!
SD card max 32 GB
12V 0,5 A
10 video streams (1 bi directionnel)
Web server
player
Power Source:Plug
Power:DC12V
Camera:3.7mm
Sensor:IMX 238 CMOS sensor
IP Rate:IP65
PoE:PoE IEEE 802.3 AF
Operating temperature range:- 40 To + 50
data sheet: https://www.beward.cn/wp-content/uploads/2018/12/DS06MP-Installation-User-Manual.pdf
https://www.activeonline.com.au/wp-content/uploads/2018/08/DS06MP-Operation-User-Manual-Eng.pdf
Prix: env 130 $ US
Be free to send me comments !
Regards
