I made (another) privacy orientated ESP32 Doorbell with IR Night-vision and video recording!
It uses ESPHome and HomeAssistant (with optionally MotionEye).
Features and parts:
- Fish-eye OV2640 HD Camera.
- IR Nightvision.
- Metal push button with LED Lights.
- DFPlayer + smoll speaker.
- 12v to 5v buck converter.
- When someone presses the doorbell button, the led ring flickers and plays a mp3 doorbell chime from a SDCard. These visual and sound confirmations were much needed according to many delivery guys
I had made one without also, and got a lot of feedback. - Recording: a http-stream can be used to record 24/7 or motion based. I chose the latter via MotionEye, due to performance on my rpi4 with 8gb and a SSD.
Was a lot of work for me personally, learned to 3d print and design and work with electronics and script in the last 5 months. Pretty steep learning curve despite being an IT specialist.
I have put my FreeCAD designs and STLβs on 2 places:
Printables: https://www.printables.com/model/805980-esp32-s3-doorbell-v2-nightvision-chime-recording
This YAML Config works flawlessly and is still stable up until now. Recent updates to ESPHome has not diminished the reliability. Due to this being a ESP32 S3, certain parameters to make the cam working are necessary. Copy and paste the config and adjust the placeholders.
Side notes: the IR Night vision LED Ring is too strong
SO I have solved this by changing the camera image settings on the fly before and after sunset. This is done via an HomeAssistant automation and 2 scripts:
- After sunrise β trigger automation β set daylight mode using following script: HA Script (github)
- After sunset β trigger automation β set night mode using following script: HA Script (github)
As you can see in the images, I have added a preview of the HomeAssistant page which shows the stream and some details. On that page I have added 2 buttons to change the image settings just in case the automation triggers above did not work.
HOWEVER, IF this is too much then check my first doorbell design which is way simpler and has less parts needed but NO NIGHTVISION
: see here.
Enjoy!
