Doorbell Notifications with snapshot & video
Recently I installed an Amcrest AD110 using Amcrest2MQTT for the doorbell press notification in HA.
Another note which will come up in my post is that I’m running Frigate in a docker with the frigate add-on for integration.
My question/goal is to get a notification with snapshot when the doorbell button is pressed and it be actionable to open the camera feed. I’m using the official HA app on Android.
What is the best way to pull the snapshot and video? If through Frigate, how do you coordinate the snapshot in frigate with the doorbell press since Frigate creates a snapshot on motion?
Is it best to keep the notification separate from Frigate and pull the snapshot/video straight from the camera when ths button is pressed?
Is there a blueprint, automation or node-red flow already created to pull the snapshot and video based on the button press?
Thanks in advance all.
Since I don’t know anything about Frigate this is likely the functionality I would go with.
if the camera feed is accessible in HA then it should be able to take a snaphot using the camera.snapshot service. I’m not sure about video but there is a camera.record service also that I think will record a video clip.
here is an automation/script I use to send my TV a snapshot from a camera if the motion detector at my back kitchen door detects motion but you should be able to modify it to be triggered by the doorbell press easily enough:
automation:
  - alias: AS Notification of Kitchen Motion
      - platform: state
        entity_id: binary_sensor.kitchen_door_motion
        to: 'on'
    condition:
      - condition: state
        entity_id: input_boolean.as_enable_kitchen_motion_notify
        state: 'on'
      - condition: state
        entity_id: switch.kitchen_sink_lights
        state: 'off'
      - condition: state
        entity_id: binary_sensor.kitchen_door_sensor
        state: 'on'
      - condition: or
        conditions:
          - condition: state
            entity_id: media_player.living_room_tv
            state: 'on'
          - condition: state
            entity_id: binary_sensor.ping_my_pc
            state: 'on'
      - if:
          - condition: state
            state: 'on'
        then:
          - service: script.as_kitchen_motion_tv_notify
      - if:
          - condition: state
            state: 'on'
        then:
          - service: notify.alexa_media
                - media_player.sunroom_dot
                type: announce
              message: "the kitchen door motion sensor was triggered"
script:
  as_kitchen_motion_tv_notify:
    alias: Notify LR TV of Kitchen Motion
    sequence:
      - service: variable.set_variable
          variable: kitchen_snap_timestamp
          value: '{{ now().strftime("%Y%m%d_%H%M%S") }}'
      - service: camera.snapshot
          entity_id: camera.kitchen
          filename: /config/www/snapshots/kitchen_{{ states('variable.kitchen_snap_timestamp') }}.jpg
      - delay: '00:00:02'
      - service: notify.shield_tv_notify
          message: "The Kitchen motion sensor has detected motion"
            duration: 5
            position: "bottom-left"
            fontsize: "medium"
            transparency: "80%"
            color: "red"
            interrupt: 0
            image:
              path: "/config/www/snapshots/kitchen_{{ states('variable.kitchen_snap_timestamp') }}.jpg"
variable:
  kitchen_snap_timestamp:
    value: 'not set'
    restore: true
it uses the “hass-variables” custom integration but you can do the same thing with an input_text.
