UPDATED: Now supports Alexa and Google devices.And updated to tts.google_translate_say
Blueprint to make a TTS announcement when a binary sensor goes from off to on, e.g. a doorbell sensor and to take a snapshot from a camera and send it to your official home assistant mobile app.
You can select a binary sensor, an echo device or google device to make the announcement and customise the announced message, a camera, a mobile device to receive the snapshot as a notification (either android or iOS) and customise the notification title and message.
NOTE: For amazon echo devices you require the alexa media player add-on.
You can announce to multiple devices by inputting a comma separated list or a group.
blueprint:
name: Doorbell - Notify Alexa and or Google and send camera snapshot to app
description: 'Make an announcement over Alexa and/or Google devices when the doorbell is pushed and send a camera snapshot to your app.'
domain: automation
input:
doorbell:
description: This is the doorbell binary sensor
selector:
entity:
domain: binary_sensor
echo_device:
description: The Alexa device to make the announcement on. Make a comma seperated list to announce on multiple devices.
selector:
entity:
domain: media_player
default: ""
google_device:
description: The Google device to make the announcement on. Make a comma seperated list to announce on multiple devices.
selector:
entity:
default: ""
message:
name: Message (Optional)
description: 'Default: "There is Somebody at the Door!"'
default: There is Somebody at the Door
camera:
description: The camera which creates the snapshot
selector:
entity:
domain: camera
notify_device:
name: Device to notify
description: Device needs to run the official Home Assistant app to receive notifications
selector:
device:
integration: mobile_app
is_ios:
name: Is it an iOS device?
description: Toggle if your selected device runs iOS, default is Android
selector:
boolean:
default: false
notification_title:
name: Notification title (Optional)
default: "There is Somebody at the Door!"
notification_message:
name: Notification message (Optional)
delay:
name: Delay (Optional)
description: Wait before creating camera snapshot
default: ""
selector:
number:
min: 0
max: 60
unit_of_measurement: seconds
mode: slider
source_url: https://gist.github.com/seamus65/294db1010ba4e27e0cd8889ef110eb24
mode: single
- platform: state
entity_id: !input 'doorbell'
to: "on"
variables:
camera: !input camera
notify_device: !input notify_device
is_ios: !input is_ios
notification_title: !input notification_title
notification_message: !input notification_message
delay: !input delay
snapshot_create_file_path: "/config/www/tmp/snapshot_{{ states[camera].object_id }}.jpg"
snapshot_access_file_path: "{{ snapshot_create_file_path | replace('/config/www','/local') }}"
- service: notify.alexa_media
- !input 'echo_device'
message: !input message
type: tts
- service: tts.google_translate_say
entity_id:
- !input 'google_device'
- delay: "{{ delay }}"
- service: camera.snapshot
entity_id: !input camera
filename: "{{ snapshot_create_file_path }}"
- device_id: !input notify_device
domain: mobile_app
type: notify
title: "{{ notification_title }}"
message: "{{ notification_message }}"
data: >
{% set android_data = {"image": "%s"} | format(snapshot_access_file_path) %}
{% set ios_data = {"attachment": {"url": "%s", "content_type": "JPEG"}} | format(snapshot_access_file_path) %}
{{ ios_data if is_ios else android_data }}
Thank you. It works great with 1 google speaker. But, I was unable to get it to work with multiple google speakers using a comma delimited list. I may be doing something wrong but the error I am getting is:
Logger: homeassistant.components.automation.doorbell_notify_google_and_send_camera_snapshot_to_app_3
Source: core.py:1399
Integration: Automation (documentation, issues)
First occurred: 1:50:33 PM (2 occurrences)
Last logged: 1:52:22 PM
While executing automation automation.doorbell_notify_google_and_send_camera_snapshot_to_app_3
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 404, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1026, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 242, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 250, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 457, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1399, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: not a valid value for dictionary value @ data['entity_id']
I have started having issues today, so I changed the selector back to media player and it seems to work better, but not sure if something has change with the supervisor update.
Is it possible to just send an notification to my iphone without the need of a camera?
maybe its possible to set a volume level to the selected echo devices?
so for example when my echo is at a very low volume level before the dorbell ring?
Unfortunately I can’t get the ios notifications to work. I’m actually having trouble clarifying path names in general, which seems to be the problem here. And defining what to add to the the allowlist as well. Any input would be appreciated for my pi installation.
this does not work for me. I get an error that alexa devices cannot be found, which makes sense because I dont have any. I left the alexa device field blank and only filled in the google device as I am attempting to cast to a chromecast only, it does not appear to skip the Alexa part…?
could I play a locally hosted mp3 instead of TTS? I would like to just play a simple doorbell chime,
instead of just having the Google Speaker say “Ding Dong!”
Funny note: I had a battle getting the MP3 to work here on some other doorbell solution.
But the Wife wanted the TTS Ding Dong, Ding Dong, Ding Dong voice back…
She finds it funny and now opens the door with a big smile
Actually, same here. The kids find it actually fun to keep hearing the TTS ding dong. I managed to solve my problem with a wireless ESP Relay. Just ring the normal door Gong trough the relay on button press. The TTS ding dong is still played though.
