Doorbell - Notify Google and send camera snapshot to app
Blueprint to make a TTS announcement when a binary sensor goes from off to on, e.g. a doorbell sensor and to take a snapshot from a camera and send it to your official home assistant mobile app.
You can select a binary sensor, a google device to make the announcement and customise the announced message, a camera, a mobile device to receive the snapshot as a notification (either android or iOS) and customise the notification title and message.
You can announce to multiple devices by inputting a comma separated list or a group.
Blueprint screen:
Blueprint to import:
blueprint:
  name: Doorbell - Notify Google and send camera snapshot to app
  description: 'Make an announcement over Google devices when the doorbell is pushed and send a camera snapshot to your app.'
  domain: automation
  input:
    doorbell:
      description: This is the doorbell binary sensor
      selector:
        entity:
          domain: binary_sensor
    google_device:
      description: The Google device to make the announcement on. Make a comma seperated list to announce on multiple devices.
      selector:
        entity:
          domain: media_player
      default: ""
    message:
      name: Message (Optional)
      description: 'Default: "There is Somebody at the Door!"'
      default: There is Somebody at the Door
    camera:
      description: The camera which creates the snapshot
      selector:
        entity:
          domain: camera
    notify_device:
      name: Device to notify
      description: Device needs to run the official Home Assistant app to receive notifications
      selector:
        device:
          integration: mobile_app
    is_ios:
      name: Is it an iOS device?
      description: Toggle if your selected device runs iOS, default is Android
      selector:
        boolean:
      default: false
    notification_title:
      name: Notification title (Optional)
      default: "There is Somebody at the Door!"
    notification_message:
      name: Notification message (Optional)
    delay:
      name: Delay (Optional)
      description: Wait before creating camera snapshot
      default: ""
      selector:
        number:
            min: 0
            max: 60
            unit_of_measurement: seconds
            mode: slider
  source_url: https://gist.github.com/seamus65/fd6d9341f0f8be76d8b81c2e3ef03624
mode: single
- platform: state
  entity_id: !input 'doorbell'
  to: "on"
variables:
  camera: !input camera
  notify_device: !input notify_device
  is_ios: !input is_ios
  notification_title: !input notification_title
  notification_message: !input notification_message
  delay: !input delay
  snapshot_create_file_path: "/config/www/tmp/snapshot_{{ states[camera].object_id }}.jpg"
  snapshot_access_file_path: "{{ snapshot_create_file_path | replace('/config/www','/local') }}"
  - service: tts.google_translate_say
      entity_id:
        - !input 'google_device'
      message: !input message
  - delay: "{{ delay }}"
  - service: camera.snapshot
    entity_id: !input camera
      filename: "{{ snapshot_create_file_path }}"
  - device_id: !input notify_device
    domain: mobile_app
    type: notify
    title: "{{ notification_title }}"
    message: "{{ notification_message }}"
    data: >
      {% set android_data = {"image": "%s"} | format(snapshot_access_file_path) %}
      {% set ios_data = {"attachment": {"url": "%s", "content_type": "JPEG"}} | format(snapshot_access_file_path) %}
      {{ ios_data if is_ios else android_data }}
Thanks! Getting an error though:
Logger: homeassistant.components.automation.doorbell_notify_google_and_send_camera_snapshot_to_app
Source: helpers/script.py:1138
Integration: Automation (documentation, issues)
First occurred: 9:15:59 PM (1 occurrences)
Last logged: 9:15:59 PM
Doorbell - Notify Google and send camera snapshot to app: Error executing script. Service not found for call_service at pos 1: Unable to find service tts.google_say
Try changing
tts.google_say
to
I have this in my configuration.yaml
tts:
  - platform: google_translate
    service_name: google_say
You would need to check what you have as yours.
I have changed the blueprint to tts.google_translate_say as that is the default
The default configuration is `tts.google_translate_say’, so if you are sharing, its best to stick to default naming, otherwise everyone will have the same problem as @luchtgitaar
I have changed it. Didn’t realise as that has been in my config for 4 years.
I haven’t used blueprints yet, but I do like how you’ve added a ‘variables’ section in there. That does make things much easier :blush:
I have been playing with them since the conference, I am not involved in the creation of blueprints, but it does feel good to be able to give back some to the community.
I think blueprints could be hugely powerful for a lot of people.
Thanks. I am getting a different error now. Also I am not able to select groups or comma separate devices. I have same sort of automation in NodeRed now, so thanks for your hard work settings this up in HA itself.
First occurred: 10:22:39 PM (2 occurrences)
Last logged: 10:23:26 PM
Doorbell - Notify Google and send camera snapshot to app: Error executing script. Invalid data for call_service at pos 1: not a valid value for dictionary value @ data['entity_id']
Source: core.py:1399
First occurred: 10:22:39 PM (1 occurrences)
Last logged: 10:22:39 PM
While executing automation automation.doorbell_notify_google_and_send_camera_snapshot_to_app
  File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 404, in async_trigger
    await self.action_script.async_run(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1026, in async_run
    await asyncio.shield(run.async_run())
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 242, in async_run
    await self._async_step(log_exceptions=False)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 250, in _async_step
    await getattr(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 457, in _async_call_service_step
    await service_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1399, in async_call
    processed_data = handler.schema(service_data)
  File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
    return base_validate(path, iteritems(data), out)
  File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
    raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: not a valid value for dictionary value @ data['entity_id']
I have raised a PR on the documation, as the service name in the example configuration.yaml shows the incorrect name, which may lead to issues with blueprints.
https://github.com/home-assistant/home-assistant.io/pull/15995
I have a similar but perhaps more advanced system if you want to copy?
The main differences:
  1. I broadcast the local doorbell message, only when we are at home.
  2. I cast the camera to local media devices, I.E Google Homes (I did also try the TV, which was fun), only we are at home.
  3. Device notify is via pushover and is split into two messages, text only, then the image, so the image does not delay the message (saves ~5 seconds).
My Home Assistant Configuration
House Doorbell Button Local Notify
alias: House Doorbell Button Local Notify
description: >-
  CCTV needs to have anonymous viewer enabled or I need to pass the username in
  the media_content_id. Note, during testing you need to turn off the
  media_player device after each test, else is will not show the video again.
  - device_id: b03ab12c707340e8849888171a79caed
    entity_id: binary_sensor.doorbell_button
    platform: device
    type: turned_on
condition:
  - condition: or
    conditions:
      - condition: state
        entity_id: person.richard
        state: home
      - condition: state
        entity_id: person.lucy
        state: home
  - data:
      cache: false
      entity_id: media_player.living_room_speaker
      message: Ding! Dong! Someone is at the door
  - data:
      media_content_id: 'http://192.168.4.11/axis-cgi/mjpg/video.cgi'
      media_content_type: image/jpg
    entity_id: media_player.office_display
    service: media_player.play_media
  - data:
    entity_id: media_player.bedroom_display
  - data:
    entity_id: media_player.kitchen_display
  - data:
      cache: false
      entity_id: media_player.lucys_room_speaker
  - data:
      cache: false
      entity_id: media_player.garage
mode: single
and
House Doorbell Button External Notify
alias: House Doorbell Button External Notify
description: 'https://github.com/home-assistant/core/issues/32236'
    platform: device
    type: turned_on
condition: []
  - data:
      message: Ding Dong! Someone is at the door. Get the biohazard suit out!
      title: Doorbell Alert☣️
    service: notify.pushover_notify_doorbell
  - data:
      filename: /config/www/tmp/front_door.jpg
    entity_id: camera.front_door_11
  - data:
        attachment: /config/www/tmp/front_door.jpg
      message: Photo of the infectious!
      title: Doorbell CCTV Photo
mode: single
Nice. Thank you
@seamus65, are you able to add a variable to raise the volume to a predefined level for the Google device?
Perhaps some basic logic as follows:
  1. turn on the Google device
  2. get the original volume level
  3. set a new volume level
  4. play TTS
  5. set original volume level
I’ll spend 5 mins looking at it now myself & might post back…
Maybe something like this using a scene?
blueprint:
  description: Make an announcement over Google devices when the doorbell is pushed
  domain: automation
  input:
    doorbell:
      selector:
        entity:
    google_device:
      selector:
        entity:
      default: ''
    message:
    camera:
      selector:
        entity:
          domain: camera
    notify_device:
        notifications
      selector:
        device:
    is_ios:
      selector:
        boolean: {}
      default: false
    notification_title:
      default: There is Somebody at the Door!
    delay:
      default: ''
      selector:
        number:
          min: 0.0
          max: 60.0
          mode: slider
          step: 1.0
    volume:
      name: Volume (Optional)
      description: Volume for announcement
      default: ''
      selector:
        number:
          min: 0
          max: 100
          unit_of_measurement: "%"
          mode: slider
          step: 5
  source_url: https://community.home-assistant.io/t/doorbell-notify-google-and-send-camera-snapshot-to-app/257953
mode: single
- platform: state
  to: 'on'
variables:
  camera: !input 'camera'
  notify_device: !input 'notify_device'
  is_ios: !input 'is_ios'
  notification_title: !input 'notification_title'
  notification_message: !input 'notification_message'
  delay: !input 'delay'
  volume: !input 'volume'
  snapshot_create_file_path: /config/www/tmp/snapshot_{{ states[camera].object_id
  snapshot_access_file_path: '{{ snapshot_create_file_path | replace(''/config/www'',''/local'')
- service: media_player.turn_on
    entity_id:
- delay:
    seconds: 1
- service: scene.create
    scene_id: before
    snapshot_entities:
- service: media_player.volume_set
    entity_id:
    volume_set: '{{ volume }}'
    entity_id:
    message: !input 'message'
- delay: '{{ delay }}'
  entity_id: !input 'camera'
    filename: '{{ snapshot_create_file_path }}'
- device_id: !input 'notify_device'
  domain: mobile_app
  type: notify
  title: '{{ notification_title }}'
  message: '{{ notification_message }}'
  data: '{% set android_data = {"image": "%s"} | format(snapshot_access_file_path)
    %} {% set ios_data = {"attachment": {"url": "%s", "content_type": "JPEG"}} | format(snapshot_access_file_path)
    %} {{ ios_data if is_ios else android_data }}'
- service: scene.turn_on
    entity_id: scene.before
    transition: 2.5
Is there a way that this automation can be setup with the following:
  1. Music player is playing some music like a radio station of spotify.
  2. someone rings de doorbel and google uses TTS to tell that there is someone at the door.
    3.Music player goes back to the music services that was playing.
That is how it works with Alexa, but I haven’t been able to check with Google yet.
I tried it here.
when there is music playing and the automation is triggerd the TTS speaks, but never returns to the music that was playing before the TTS.
Sorry, I am not as experienced with the google devices and can’t see how to do it.
i almost have the same setup, except a nice addition would be to show snapshot on nesthub or chromecast for 1 minute , which i have setup.
