Script seems acting strange.
under the “Google” options, i can select media_player.study / media_player.livingroom individually… no problems…Audio is sent to these devices.
But when i enter media_player.shed_speaker …i get the following error Doorbell - Front Door: Error rendering Doorbell - Front Door delay template: offset should be format 'HH:MM', 'HH:MM:SS' or 'HH:MM:SS.F'
Question :
Do i add multiple devices in the Google field like: media_player.study,media_player.livingroom,media_player.shed_speaker ?
Why is it when i select media_player.shed_speaker do i only get the error above?
Sorry, I don’t have a Google device at the minute to test this out.
If you manage to find a solution please share here to help others out that might have similar issues.
Not POE. I have the pro, which is hard wired for power, but WiFi.
I have the ring integration and the ring2mqtt integration, which picks up the button press really well.
You can also view the last recorded video clip in HA
I am not using it to send my stream to a google hub.
It isn’t possible to get a live stream from the eufy doorbell. The reason is that rtsp or onvif isn’t supported yet.
You can make a automation that when the doorbell is pressed it will send you a screenshot to your mobile phone. There are plenty blueprints for it to make a automation for it.
I have been trying to get this to work to notify multiple mobile app devices. I have tried csv list with the webhook ids and the entity ids of the mobile app devices but nothing works. There must be a way to notify multiple devices without the need to create a second automation
Hi everyone, I’m very new to HAOS and installed a working version I’d say a month ago. I was speaking with a few others in the HA Discord channel and thought I’d post my modifications in order for this blueprint to work for me and hope it helps anyone else that comes across this thread.
I had to change the TTS from google_translate_say to tts.speak and had to comment out the #delay for it to continue through the automation. Took me a few hours of tinkering (with my limited skills) to figure out but finally go it working with my Reolink.
blueprint:
name: Doorbell - Notify Google and send camera snapshot to app
description:
Make an announcement over Google devices when the doorbell is pushed
and send a camera snapshot to your app.
domain: automation
input:
doorbell:
description: This is the doorbell binary sensor
selector:
entity:
domain:
- binary_sensor
multiple: false
google_device:
description:
The Google device to make the announcement on. Make a comma seperated
list to announce on multiple devices.
selector:
entity:
domain:
- media_player
multiple: false
default: ""
message:
name: Message (Optional)
description: 'Default: "There is Somebody at the Door!"'
default: There is Somebody at the Door
camera:
description: The camera which creates the snapshot
selector:
entity:
domain:
- camera
multiple: false
notify_device:
name: Device to notify
description:
Device needs to run the official Home Assistant app to receive
notifications
selector:
device:
integration: mobile_app
multiple: false
is_ios:
name: Is it an iOS device?
description: Toggle if your selected device runs iOS, default is Android
selector:
boolean: {}
default: false
notification_title:
name: Notification title (Optional)
default: There is Somebody at the Door!
notification_message:
name: Notification message (Optional)
delay:
name: Delay (Optional)
description: Wait before creating camera snapshot
default: ""
selector:
number:
min: 0.0
max: 60.0
unit_of_measurement: seconds
mode: slider
step: 1.0
source_url: https://community.home-assistant.io/t/doorbell-notify-google-and-send-camera-snapshot-to-app/257953
mode: single
- platform: state
entity_id: !input doorbell
to: "on"
variables:
camera: !input camera
notify_device: !input notify_device
is_ios: !input is_ios
notification_title: !input notification_title
notification_message: !input notification_message
delay: !input delay
snapshot_create_file_path:
/config/www/tmp/snapshot_{{ states[camera].object_id
snapshot_access_file_path:
"{{ snapshot_create_file_path | replace('/config/www','/local')
# changed from google_translate_say to tts.speak for HA CORE 2023.10.5
- service: tts.speak
cache: true
media_player_entity_id:
- !input google_device
message: !input message
entity_id: tts.google_en_com
# had to comment out delay for it to work propery
# - delay: "{{ delay }}"
- service: camera.snapshot
entity_id: !input camera
filename: "{{ snapshot_create_file_path }}"
- device_id: !input notify_device
domain: mobile_app
type: notify
title: "{{ notification_title }}"
message: "{{ notification_message }}"
'{% set android_data = {"image": "%s"} | format(snapshot_access_file_path)
%} {% set ios_data = {"attachment": {"url": "%s", "content_type": "JPEG"}} | format(snapshot_access_file_path)
%} {{ ios_data if is_ios else android_data }}'
Hi, I know this is a older thread, but is it pissible to play a notification on a Google Nest Mini and resume playing on it what was playing before the notification was sent?
