I made a simple doorbell using one input pin of the raspberry pi. When the doorbell gets pressed the following happens:
- an amplifier gets enabled
- a sound is played via mpd over the amplifier
- some lights in the house will flash so deaf people will notice it too
- sends a message via pushbullet to my phone
- after 15 seconds the amplifier will be disabled again to save power
The door switch is connected to GPIO-22 with a pullup resistor and a 100nF capacitor to ground for preventing false triggers and debouncing.
The enable-pin of the amplifier is connected to GPIO-16. It is not a very strong amplifier, but if anyone is interested I can share the schematics and pcb-layout (I build it myself).
For mpd you have to make a playlist with the sound you want to play. I have now a rooster (haan in my native language). Of course you are free to play any sound yu want.
Relevant part of configuration.yaml file:
media_player doorbel:
- platform: mpd
host: 127.0.0.1
notify:
- name: mypushbullet
platform: pushbullet
api_key: !secret pbapi
switch: !include switch.yaml
binary_sensor: !include binsensor.yaml
in switch.yaml
- platform: rpi_gpio
ports:
16: Enable Amp
in binsensor.yaml
ports:
22: Deurbel
pull_mode: UP
invert_logic: true
Automation section
- alias: Deurbel ingedrukt
- entity_id: binary_sensor.deurbel
platform: state
to: 'on'
- service: switch.turn_on
entity_id: switch.enable_amp
- service: light.turn_on
entity_id:
- light.Bureau_Paul
- light.Eetkamer_Tafel
- light.woonkamer
- light.koof
flash: long
- service: media_player.volume_set
entity_id: media_player.main
volume_level: 0.99
- service: media_player.play_media
entity_id: media_player.mpd
media_content_id: haan
media_content_type: playlist
- service: notify.mypushbullet
data_template:
message: "Er is iemand aan de deur!"
- delay: 00:00:15
- service: switch.turn_off
Next step is to program different sounds for different times of the day.
