I am using doorbird (works a treat) with the native integration, however I also had to add a YAML configuration with the access keys for the DB device. I did this because I was unable to set these values in the integration setup.
I think it’s saying this because it wants me to remove the DoorBird configuration from the YAML file, but without this, HA can’t connect to the DoorBird.
Where can I report this error?
Any ideas?
Thanks.
See below error:
Logger: homeassistant.components.doorbird
Source: helpers/config_validation.py:751
Integration: DoorBird (documentation, issues)
First occurred: 9:57:38 (1 occurrences)
Last logged: 9:57:38
The 'doorbird' option is deprecated, please remove it from your configuration
