Good afternoon, I am having the exact same issue and can’t get the automation to work when I press the button. However, manually firing the event triggers the automation:
I added the event types in the integration configuration (button,motion) and they are showing up under Favorites in the doorbird HTTP(S) calls.
I added a schedule for both, motion and button events are all blue.
However, when pressing the button on the doorbird, the automation doesn’t run.
Any other ideas or suggestions where I could be stuck?
With the core intergration you don’t need to add the button and motion in doorbird config. Only in HA when setting up the intergration you need to fill them in. The intergration will take care of creating them in doorbird. You only need to make the schedule afterwards. It could take some time (5 min max) for the intergration to create the evens.
Then I don’t know what else can be wrong.
How else or where else can I do troubleshooting if everything is setup according to the instructions.
I mean, I can see the live view and open the relay from within a HA Dashboard with no problem so I don’t think its a communications issue.
