I hope that someone can help me out with a little problem.
I have a DoorBird integrated in Home Assistant for a while to show the camera pictures for “Live”, “Last Ring” and “Last Motion”.
Now I tried to create automations to send a notification via Pushover for the events “Motion” and “Ring”. But it seems that the events are not fired at all by Home Assistant. I can fire them manually using the Events page. Here is my configuration and automation file.
doorbird:
token: !secret doorbird_token
devices:
- host: <ip>
username: <username>
password: <password>
monitored_conditions:
- doorbell
- motion
- id: notify_3
alias: Front Door Ring
- platform: event
event_type: doorbird_front_door_button
condition: []
- service: notify.pushover
title: "Haustür"
message: "Es hat an der Haustür geklingelt."
In the Doorbird app, go to Administration -> HTTP Calls. You should see the URL that the Doorbird is calling when the doorbell is pressed. You should be able to call this URL from a web browser. If the response is “OK” then the event should have been fired and the automation triggered in HA.
Thanks for the tip. I called the URL and received “OK”. I also received the notification as defined in my automation. But it’s still not working if someone pushed the doorbell.
You are the second report I’ve seen of the Doorbird not calling the configured URLs when an event happens. I would contact Doorbird support and see what they say. Could be an issue on their end with a particular device/firmware.
I had similar issue (see above). Today I spent half of Sunday to troubleshoot and fix the issue. It seems that eventually it stared working when I removed the user I used for hass integration (not admin) from DoorBird iPhone App. Then restarted Doorbird. Then added the user back with setting the operator permission to on. Saved the config. Restarted Doorbird again… and it started working back! Now both event’s are fired up. Funny I had the correct url in HTTP Call setting of Doorbird App, all the time but anyway it was not working. So try to remove and re-add user and let me know.
@LKrisM did you manage to contact DoorBird support, and did they assist you to resolve this?
I have similar symptoms. No problem injecting an event via the Events dev page, but no luck with a response directly from the Intercom. However in my case, if I call the URL shown in the Admin → HTTP page in the DoorBird app, https://hassio.local:8123/api/doorbird/front_door_intercom_button?token=xxxxxxxxxx within the same LAN that the DoorBird Intercom and hass.io server are on, then the trigger within HA also works.
I had noted during the initilisation log output this entry:
2019-04-01 09:29:49 INFO (SyncWorker_1) [homeassistant.components.doorbird] Registered for doorbell pushes from DoorBird “Front Door Intercom”. Use the “doorbird_front_door_intercom_button” event for automations.
Which seemed to suggest that all was in order as expected. As I mentioned, I’ve called the URL shown for the DoorBird app and the response is “OK”, and this also successfully triggers the HA integrated event. This suggests the connection break is not in the DoorBird app nor in the HA processing but maybe something to do with the URL the DoorBird intercom is actually expressing.
@Tscherno: Can you please open your Doorbird app go to Administration, HTTPS Calls and verify your HTTPS requests - if they match the names of the events youre listening for in HA?
Hi, i have an indoor A1101 , you can create extra buttons on it (widgets)
i have added a https api call , but seems it doesnt support POST?
how can we add custom tiles on it, to trigger an light for example? how can we do that with an http call ?
webhook only supports POST
edit: nm, found it, i can just create random events with a name, that will create somekind of webhook without POST, that i can use to trigger other thins
Have you made sure the schedules for each event are set under administration?
Under advanced settings for teh doorbell and under motion sensor settings for the motion detection.
