A few days ago (maybe after upgrading to core-2021.3), my DoorBird integration stopped working. I removed the integration and tried to reinstall the integration. I now get this error in the log:
Logger: homeassistant.config_entries
Source: helpers/network.py:124
First occurred: 11:06:57 AM (1 occurrences)
Last logged: 11:06:57 AM
Error setting up entry 192.168.220.162 for doorbird
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 248, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/doorbird/__init__.py", line 160, in async_setup_entry
if not await _async_register_events(hass, doorstation):
File "/usr/src/homeassistant/homeassistant/components/doorbird/__init__.py", line 204, in _async_register_events
await hass.async_add_executor_job(doorstation.register_events, hass)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/doorbird/__init__.py", line 281, in register_events
hass_url = get_url(hass)
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 84, in get_url
request_host = _get_request_host()
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 124, in _get_request_host
raise NoURLAvailableError
homeassistant.helpers.network.NoURLAvailableError
Can anyone confirm that this integration works with core 2021.3 ?
Any ideas?
I have the same problem, I downgraded to core-2021.2.3 from core-2021.3.2. And it started to work again.
Not sure why yet. Have not found anything in the bug tracker about it. I will keep looking and if I come to some sort of conclusion about what it is, I will try to create a ticket for it
This has been resolved. For the next person who hits this, go to Configuration → General
There you will find the External URL and Internal URL settings.
Once you set those (and Save) you can either restart HA or reset the Doorbird integration.
To reset it, go back to Configuration → Integrations → Doorbird, disable the integration, and re-enable the integration to get it to restart. After doing the Disable/(re)Enable procedure, the Doorbird integration is working again.
Thanks to @nilst for pointing me in the right direction.
Hello, I have this issue using Hassio 2022.2.5
I can’t find the entry for External URL and Internal URL when I go to configuration → Settings.
And when I add the external url and internal url as described here, it tells me that the configuration is not valid and the integration is not found
@roberreiter – I am still using 2021.11.5 so I haven’t quite hit the new configuration UI layout, yet.
I would recommend you NOT follow those instructions to configure via YAML, because if you try to configure via YAML then you can’t configure via the UI. You should be configuring via the UI.
I suspect the location of those settings moved between 21.11 and 22.2. I only upgrade every 3-4 months. But I would suggest you remove that configuration and then configure via the UI to find the Internal and External URL settings. I’m sure they still exist, somewhere, but I don’t have a 2022.2 install to find them for you.
Yes, it looks like the configuration page there, and when I click on “Einstellungen” which is “settings” I see the page I already posted before
Hi, just found it.
I had to activate the advanced mode features in the user menu for user settings.
Now I included the external and internal IP and it works
