Any news here? I think the Axis component uses endpoints to get notified of events from the binary sensors. Maybe you can check there?
I just pushed new code that registers HA with the device, which then creates an event when the doorbell rings. Iām not sure how to make this useful in the frontend, but any changes needed there should be minimal.
At the moment the Axis component uses RTSP protocol to receive subscribed events. There is work by another community member to add a web endpoint to give support mainly to older devices that doesnāt support the RTSP events.
The last images are not visible anymore (probably due to an firmware upgrade in doorbird?) Did something change here?
Although the api manual states that the history.cgi event param is not mandatory, it however seems like it is!
Test without event param:
ā ~ curl -u user0001:passwd -v http://192.168.1.9/bha-api/history.cgi\?index\=1
* Trying 192.168.1.9...
* TCP_NODELAY set
* Connected to 192.168.1.9 (192.168.1.9) port 80 (#0)
* Server auth using Basic with user 'user0001'
> GET /bha-api/history.cgi?index=1 HTTP/1.1
> Host: 192.168.1.9
> Authorization: Basic #hash
> User-Agent: curl/7.50.3
> Accept: */*
< HTTP/1.1 204 No Content
< Content-Type: text/plain
< Date: Thu, 28 Dec 2017 19:27:31 GMT
< Server: lighttpd/1.4.45
* Curl_http_done: called premature == 0
* Connection #0 to host 192.168.1.9 left intact
Test with event param:
ā ~ curl -u user0001:passwd -v http://192.168.1.9/bha-api/history.cgi\?index\=1\&event\=doorbell
* TCP_NODELAY set
> GET /bha-api/history.cgi?index=1&event=doorbell HTTP/1.1
> Host: 192.168.1.9
> Accept: */*
< HTTP/1.1 200 OK
< Content-Type: image/jpeg
< Content-Length: 30867
< X-Timestamp: 1514398891
< X-Count: 35
< Date: Thu, 28 Dec 2017 19:33:06 GMT
I think DoorBird broke this with a firmware upgradeā¦
I submitted a issue: https://github.com/Klikini/doorbirdpy/issues/3
With version 0.61 your code is now live. Any thoughts on how to use the doorbell_events? I donāt āget itā yet.
What I understand from the code is that when doorbell_events are activated, Home Assistant is opening a API endpoint for the DoorBird and will configure the DoorBird API (on startup) with notifications to call the Home Assistant API.
I will leave some feedback when itās working, but I still need to upgrade Home Assistant.
You can use it in automations, like this one that will add entries to the logbook:
- alias: Doorbell
- platform: event
event_type: doorbird_doorbell
- service: logbook.log
message: rang
More helpful examples of automations are welcome in the component documentation
Curious if you got this working yet and what you think
Iāve tried this automation and get this error:
2018-01-24 14:42:40 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from ādoorbird ipā
Iāve double checked the Doorbird logon details in config.yaml and itās right, sounds like Doorbird is not auth to HA? Any ideas?
I realize now that Iām an idiotā¦
My test instance of HA doesnāt have an API/HTTP password, so it worked and I didnāt think to authenticate API calls. I will work on a fix ASAP.
Not an idiot at all, easily over looked! Let me know when you a chance to correct it and Iāll test.
Many thanks!
I have pushed a fix and created a pull request, so now itās up to the HA devs to accept it.
While I havenāt moved over to this APIās ring notification (still using the proxy version), I have tied this into TTS using Bluetooth speakers with my RPi. I have my Pi connect to my Echos, and they will let me know when someone is ringing the door. There are a few known issues connecting to some Echo devices using RPis, but my Echo dot seems to consistently work. Other ideas may be to flash some lights, send some push notifications, etc.
Hereās my automation converted to use the trigger (but untested). Probably doesnāt make sense to put it in the documentation as Iām using multiple unofficial components to do this.
- id: NotifyDoorbell
alias: 'Notify of ringing doorbell'
initial_state: 'on'
platform: event
service: tts.google_say
entity_id: media_player.tts_bluetooth_speaker
message: 'Ding Dong! Someone is at the front door!'
doorbird_doorbell event now works as of 0.63 - thanks @Klikini!
hereās my working config for playing the doorbell on Sonos if anyone needs it:
an automation:
- alias: Doorbell
- platform: event
- service: script.turn_on
entity_id: script.doorbell
calls this script:
doorbell:
alias: Ring Doorbell
sequence:
- service: media_player.sonos_snapshot
entity_id: media_player.kitchen
- service: media_player.volume_set
volume_level: 0.60
- service: media_player.play_media
media_content_id: http://10.0.26.20/sounds/doorbell.mp3
media_content_type: music
- delay:
seconds: 4
- service: media_player.sonos_restore
Thank you @reynos, this works perfectly. The sonos_snapshot and sonos_restore services where new to me, but this is brilliant to be able to save and restore the state of the speaker.
My issue was that the event was never triggered. I found that when I went in to the Doorbird APP under Administration and HTTP Calls the address of my HomeAssistant server was set to localhost - when changing this to the internal IP of the server the Event was now triggered when pressing the Doorbird Button.
Hey @Klikini I just enabled SSL and the doorbell event seems to have broken, can you check please? Thanks.
I think this would happen because the DoorBird is still connecting to HA using the local IP and not using HTTPS.
Iām not sure of how to get the actual hostname, Iāll look into it.
I can connect locally to my HA instance using https://10.x.x.x (albeit after a browser warning that the URL does not match the cert) if thatās any helpā¦
Did you installed a valid certificate on your HA instance? Maybe the DoorBird can only deal with valid certificates. If so, the DoorBird must connect by hostname, not by ip. Please review the DoorBird notification parameters first by making a request to your DoorBird api, something like:
http://<deviceip>/bha-api/info.cgi
