The current DoorBird component code gets the LAN IP of the HA machine and uses that. Once I get time to work and test it, I’ll attempt to read the base_url option of the http component and use that instead, otherwise fall back to the IP address if it isn’t set up.
If you need more info that this I’ll PM you…
http:
api_password: !secret http_api_password
ssl_certificate: !secret ssl_certificate_loc
ssl_key: !secret ssl_key_loc
base_url: !secret base_url
The component should be using the base_url, so double-check that it’s correct.
Otherwise, please go to http://_doorbird_lan_ip_here_/bha-api/notification.cgi, log in with the same user account you have in your component configuration. It should look something like this:
I finally had time to troubleshoot this on my setup. Your instructions above do fire the doorbell event if i use the local IP address. Also, if in the Doorbird app i go into Admin and under HTTP Calls I change the fully qualified domain name (eg duckdns.org) to the local IP (10.x.x.x) it all works fine, but of course this setting does not stick once I restart HA. Is a solution to set the URL to LAN IP instead of FQDN?
First off thanks so much for this! I have the doorbell event working great, my question is does this work with any other events? Motion to be more specific? Thanks
I would like to use duckdns domain as base_url, but if I do it, it doesn’t work because Doorbird tries to reach ha server through duckdns, and not through local ip. I have to set local ip in base_url to get it working.
Please, can you add a “url” property to Doorbird component, and use it instead of base_url? You can use base_url if component’s url is not defined (as telegram component does). So we can have base_url with duckdns, and Doorbird url with private ip.
My proxy solution just stopt working, still had no time to test this component. So I thought maybe this is the moment…
When I was reviewing my current configuration I noticed that my api notifications were named “legacy”, also the event is now called doorbell1 instead of doorbell. So I grabbed the latest api manual and guess what… They created a hole new api called schedule.cgi OMG!!, and they have stated that the old notifications are migrated. But when reviewing the schedule.cgi api a lot of paramaters are messed up or missing…
Also getting all these 401 - Unauthorized on api requests, seems like they also introduced a new permisssion called “API-Operator”.
DoorBird listen: For the sake of backwards compatibility don’t turn it off by default for current (api) users!!!
Also would like to see the motion, i was using the one from basschipper, which worked like a charm. Including the motion, i use that to turn on the porch lights since the motion sensor has a nice detection around my door. So i know the notification url did work in the past but since the api updates i am getting those 401’s too. Hence why i am also looking into this direction since if it has motion then i’ll be all set too if you need me to test anything, just let me know.
I am trying to set up an automation that plays a ring over my home speakers when the door bell is pushed, but I can’t find the sensor that would trigger that automation. I am sure I’m just missing it.
