I had set up Home Assistant in August 2020, but didn’t do much with it and eventually turned it off due to competing priorities. This ran under a Raspberry Pi 3B along with an Aeotec Z-Stick Gen5 running on firmware V1.1.
Fast forward two years and I have some additional time and my 5th Grade son has some interest in tech projects. Together, we recently started using Home Assistant for our home. We kept the Z-wave network on the Aeotec Z-Stick Gen5 stick, but ended up completing reinstalling Home Assistant Core 23.6 / 10.2. The setup went very smooth and the new install detected my 2 year old Z-Wave network (form the Z-stick). However, there were some issues. Most of these nodes were wired-in always on nodes comprised on primarily light Leviton Z-Wave 300 Series (before Z-Wave Plus) light switches. However, some of the nodes were unresponsive. In Home Assistant, changing the state of switch would often result in the UI being correctly updated. However, when trying to change the state of some switches, the UI would update, but a few seconds later revert to the previous state. The nodes that work are dependable, but the nodes that don’t work just aren’t working as expected.
We took a few steps to try and reconcile this situation:
- We performed a network heal; this did not fix the problem.
- We did a z-wave unpair followed by a z-wave pair with the z-stick for the problem nodes; this did not fix the problem. We repeated this along with additional heal operations and still are facing the same issue.
What should we consider for next steps?
- Should we be on a newer version of the Z-stick firmware (currently on V1.1)?
- We’re considering saving a backup, updating the firmware, and factory resetting our Z-stick, but we’re wondering if there would be a simpler way. If we do reset the Z-stick will we need to do anything to delete the current z-wave devices?
Any help of guidance would be appreciated! Thanks in advance for any help!
