Started today with my HassIO and already found my first problem.
I have a doorbell switch.ringklocka that I cant get to change state from on to off.
What am I doing wrong?
It is a doorbell that uses Telldus Live 433mhz.
Even if I go to Developer Tools --> States. And there, change the stat of the entity to ‘off’ it changes. But when I press the off button, I can see a popup that says “Turned off…” but nothing happens.
Ok, I’ve tried every device and most pop up saying “wrong device selected”. One worked which I believe is the same as your image but it does not send the signal to home assistant.
The switch is connected in HA. if it is on in Telldus and I turn it off in HA it is mirrored to Telldus. If I push the door bell, I can see it lights up in telldus but that is never sent to HA.
