Would it be possible for someone to create a a dosing pump calculator for hydroponics? I can set all the pumps up in esphome and give them IDs etc but then I need help with the rest:
Something like where you input the system volume (400 litres for example) and then the list of nutrients (pumps in esphome) and the amount you need to dose per litre (every nutrient has a set amount of doses per system litre and it’s all worked out. That dosing info then gets sent to esphome so it’s saved on the ESP and not triggered from HA in case of connection issues.
Also, calibration for each pump.
Many thanks
