Dosing Tank Card — visualize chemical dosing tank levels
Lovelace card to track the level of a liquid dosing tank (chlorine, pH-, pH+, flocculant, algaecide...) based on pump run time.
No special "smart dosing pump" required — works with any switch/input_boolean/binary_sensor that reflects when the pump is running (smart plug, filtration pump slaving, threshold helper on power draw, pool controller auxiliary...).
Features:
  • Animated SVG tank with configurable liquid color
  • Real-time pump badge, remaining volume, today's consumption, 7-day runtime
  • 7-day bar chart built from HA history, no extra sensors needed
  • Low-level alert with configurable threshold
  • Multilingual: English, French, Spanish, German, Italian, Dutch
GitHub: GitHub - ADNPolymerase/ha-dosing-tank-card: Home Assistant Lovelace card — track liquid dosing tank level (chlorine, pH−, pH+, flocculant…) based on pump runtime · GitHub
HACS custom repo, store submission pending.
More of my Home Assistant projects: ADNPolymerase — Home Assistant Projects
