I’m kind of having a hard time, sending a double notification on a specific trigger/condition.
I’m trying to send a notification via telegram to 2 different chatids, so basically 2 notifiers.
I figured out how to use an AND statement in the condition, but this somehow doesn’t work the action does it?
Also, just FYI, when pasting code examples here in the forum, use the “Preformatted text” option and not the “Blockquote”, that way we can see your layout in case it is something as simple as a spacing issue that is causing the problem. Also, its just easier to read and find the problem.
Blockquot is better for a single line, such as drawing attention to something someone should type at the command line, such as:
sudo systemctl restart home-assistant
But it does not retain the format of your text, such as the layout of spaces in YAML code, so for that, you would use “Preformated text”, so it looksl like this:
This is an action statement, so it is indeed an AND. It would only be an OR if a list was used in the trigger, but the action in list form is always an AND unless you have conditions, such as:
I assume PhyberApex that you were saying that if it was in a trigger it would be an OR and not an AND, but it was a little confusing, as it could have been interpreted that you were saying a list under actions would be an OR scenario.
