Hi!
I have the following setup:
- 1 wemos d1 mini with remote reciever
binary_sensor.galben_2 ( entity) with instant ON/OFF when the button is pressed
- 1 sonoff dimmer
light.sonoff_1000dbb5a7 (entity)
- 1 automation
if binary sensor is ON then toggle light
- desired automation:
if the remote button is pressed twice (ON-OFF-ON-OFF) in less than a second or maybe two, then if brightness is low make it high and reverse.
I have tried to achieve that also in esphome, also in homeassistant, I had no succes, all info about this idea is poor on documentation and also on internet. I have no ideea to make a trigger for less than desired time (in my case 1-2 seconds).
Any suggestions? I feel I am waisting so much time on this issue and I need some help.
Thank you!
I have seen such a function with buttons in tasmota. https://tasmota.github.io/docs/Buttons-and-Switches/ Please see this. There are more options .
There is something similar on esphome under double click and multi click options but I can’t manage to work in my setup. Thanks!
I had some inspiration in this morning and the solution is pretty simple - wait for trigger - timeout
alias: Lustra telecomanda
description: ''
- platform: state
entity_id: binary_sensor.galben_2
to: 'on'
condition: []
- service: light.toggle
data: {}
entity_id: light.sonoff_1000dbb5a7
- wait_for_trigger:
- platform: state
to: 'on'
timeout: '1'
continue_on_timeout: false
- service: light.turn_on
brightness: >
{% if states.light.sonoff_1000dbb5a7.attributes.brightness|default(255) < 100 %}
255
{% else %}
1
{% endif %}
mode: single
