Hello everyone, I am new to the exciting world of Home Assistan.
I managed to enter data from my Acurite 5 in 1 weather station with the RTL_433 plugin to the MQTT bridge, which is configured in protocol 40
My problem this is that in the same RTL_433 to the MQTT bridge, I want to get the data from other devices by 433 MHz, like
the magnetic sensors, which are in the doors and also work in the 433MHz frequency.
I receive information from an Acurite temperature/humidity sensor AND a maverick thermometer using RTL-433 and I publish it to my Mosquitto (Mqtt) set up In home assistant, I use node-red to handle the information and create entities and then I use those entities in automations and scripts. Probably an easier way…but I wanted to learn about node-red.
The information is in topic rtl_433. (note: the topic is whatever you put after events= )
you can add user= and password= between the quotes if you use mosquitto authentication.
The events will come in mixed…but clearly identified. You’ll want to follow topic: rtl_433/# where rtl_433 is whatever you picked as an event name.
