I have recognized, that my 3 zigbee-sensor - connected via zigbee2mqtt - are double and I have no idea why.
I’m using the MQTT integration ad there I see 3 devices and 14 entities - which is okay. But when I dig in, I see the the sensors are named with _2
at the end.
i.e. sensor.xiaomismart_1_temperature_2
When I go to Setting/Entities I see sensor.xiaomismart_1_temperature
and sensor.xiaomismart_1_temperature_2
: the first from integration
and the second from MQTT
Same for the other entities.
I assume that’s caused by my template sensor which I use to correct and round the value.
# Xiaomi Temperatur- und Luftfeuchtigkeits-Sensor
- platform: mqtt
name: "XiaomiSmart-1 Temperature"
state_topic: "zigbee2mqtt/XiaomiSmart-1"
unit_of_measurement: '°C'
value_template: "{{ (value_json.temperature + 0.2) | round(1) }}"
availability_topic: "zigbee2mqtt/bridge/state"
device_class: "temperature"
How could I clean up and get rid of the double sensors? Is there another option to correct and round without doubling sensors?
