Double Take after update
[FATAL tini (7)] exec /bin/bash failed: Input/output error
does anyone have an idea what’s going on
does anyone have an idea how to fix the error?
Check your logs, homeassistant, supervisor and give more description.
I can take a guess, your disk is failing, docker need upgrade or restart…
Hi
the hard drive is a new ssd drive.
I’ve already restarted without success.
i can install and start other addons.
only double take does not want to start
22-10-26 13:57:44 INFO (SyncWorker_5) [supervisor.docker.interface] Cleaning addon_c7657554_double-take application
22-10-26 13:57:44 ERROR (SyncWorker_1) [supervisor.docker.manager] Can't create container from addon_c7657554_double-take: 409 Client Error for http+docker://localhost/v1.41/containers/create?name=addon_c7657554_double-take: Conflict ("Conflict. The container name "/addon_c7657554_double-take" is already in use by container "e8e93bcfab596eb58608b1fa836ba0182b8d491b3259a599db38d47d19aab968". You have to remove (or rename) that container to be able to reuse that name.")
22-10-26 13:57:44 ERROR (MainThread) [supervisor.addons.addon] Watchdog restart of addon Double Take failed!
22-10-26 13:57:44 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning addon_c7657554_double-take application
22-10-26 13:57:44 WARNING (SyncWorker_7) [supervisor.docker.network] Can't disconnect container from default: 500 Server Error for http+docker://localhost/v1.41/networks/ab9e140cc062e27f9cc6eea298af5bbadcdb15b7f8e74c436e4eacd4cd118c6c/disconnect: Internal Server Error ("Container e8e93bcfab596eb58608b1fa836ba0182b8d491b3259a599db38d47d19aab968 is marked for removal and cannot be connected or disconnected to the network")
22-10-26 13:57:45 ERROR (SyncWorker_7) [supervisor.docker.manager] Can't start addon_c7657554_double-take: 404 Client Error for http+docker://localhost/v1.41/containers/e8e93bcfab596eb58608b1fa836ba0182b8d491b3259a599db38d47d19aab968/start: Not Found ("No such container: e8e93bcfab596eb58608b1fa836ba0182b8d491b3259a599db38d47d19aab968")
22-10-26 13:57:45 ERROR (MainThread) [supervisor.addons.addon] Watchdog restart of addon Double Take failed!
22-10-26 13:57:46 WARNING (MainThread) [supervisor.addons.addon] c7657554_double-take is already running!
22-10-26 13:57:47 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on c7657554/aarch64-addon-double-take with version 1.13.0
22-10-26 13:57:47 ERROR (SyncWorker_5) [supervisor.docker.interface] Container addon_c7657554_double-take is not running
22-10-26 13:57:47 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Double Take is failed, restarting...
22-10-26 13:57:47 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_c7657554_double-take application
22-10-26 13:57:47 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_c7657554_double-take application
22-10-26 13:57:47 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning addon_c7657554_double-take application
22-10-26 13:57:47 WARNING (SyncWorker_6) [supervisor.docker.interface] Can't grep logs from c7657554/aarch64-addon-double-take: 404 Client Error for http+docker://localhost/v1.41/containers/be94fa2be576531be8b92e02d72fd86973d5d6a48c3fc3da89a6845908b8968f/json: Not Found ("No such container: be94fa2be576531be8b92e02d72fd86973d5d6a48c3fc3da89a6845908b8968f")
22-10-26 13:57:48 ERROR (SyncWorker_3) [supervisor.docker.manager] Can't create container from addon_c7657554_double-take: 409 Client Error for http+docker://localhost/v1.41/containers/create?name=addon_c7657554_double-take: Conflict ("Conflict. The container name "/addon_c7657554_double-take" is already in use by container "b00e01a6bf6889fc615ef9a8577b2e2066885f1c1385da692fccd33b53ba09b0". You have to remove (or rename) that container to be able to reuse that name.")
22-10-26 13:57:48 ERROR (MainThread) [supervisor.addons.addon] Watchdog restart of addon Double Take failed!
22-10-26 13:57:50 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on c7657554/aarch64-addon-double-take with version 1.13.0
22-10-26 13:57:50 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Double Take is failed, restarting...
22-10-26 13:57:51 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Double Take is failed, restarting...
22-10-26 13:57:51 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_c7657554_double-take application
22-10-26 13:57:51 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_c7657554_double-take application
22-10-26 13:57:51 INFO (SyncWorker_7) [supervisor.docker.interface] Cleaning addon_c7657554_double-take application
22-10-26 13:57:51 ERROR (SyncWorker_6) [supervisor.docker.manager] Can't create container from addon_c7657554_double-take: 409 Client Error for http+docker://localhost/v1.41/containers/create?name=addon_c7657554_double-take: Conflict ("Conflict. The container name "/addon_c7657554_double-take" is already in use by container "c536a76f124cef129d5703d27402765870432e7534dc24a4a2d054a53274fbb8". You have to remove (or rename) that container to be able to reuse that name.")
22-10-26 13:57:51 ERROR (MainThread) [supervisor.addons.addon] Watchdog restart of addon Double Take failed!
22-10-26 13:57:53 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on c7657554/aarch64-addon-double-take with version 1.13.0
22-10-26 13:57:54 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Double Take is failed, restarting...
22-10-26 13:57:54 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_c7657554_double-take application
22-10-26 13:57:54 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_c7657554_double-take application
22-10-26 13:57:54 INFO (SyncWorker_5) [supervisor.docker.interface] Cleaning addon_c7657554_double-take application
22-10-26 13:57:54 ERROR (SyncWorker_7) [supervisor.docker.manager] Can't start addon_c7657554_double-take: 409 Client Error for http+docker://localhost/v1.41/containers/de25ee7cedff477d1168ed0f18aeb50bd019d1ff3a96047680c3796b5cdfe7e8/start: Conflict ("container is marked for removal and cannot be started")
22-10-26 13:57:54 ERROR (MainThread) [supervisor.addons.addon] Watchdog restart of addon Double Take failed!
22-10-26 13:57:54 ERROR (SyncWorker_1) [supervisor.docker.manager] Can't create container from addon_c7657554_double-take: 409 Client Error for http+docker://localhost/v1.41/containers/create?name=addon_c7657554_double-take: Conflict ("Conflict. The container name "/addon_c7657554_double-take" is already in use by container "7c1c76d92fccc975dd0f8fcb876d545d9794a8fc4bd7520f7e554b4116956e3b". You have to remove (or rename) that container to be able to reuse that name.")
22-10-26 13:57:54 ERROR (MainThread) [supervisor.addons.addon] Watchdog restart of addon Double Take failed!type or paste code here
I will try to remove double take addon and this other container with portainer and install double take again.
I uninstalled double-take, what other two addons are you referring to.
Your log tells you that you have a conflict. Open portainer and check that container and remove it. Than install double take
I can’t find the error. I uninstalled it but it didn’t do anything
We don’t understand each other. When you install some addon it creates something that is called container. You probably before did install and then removed and installed again double take. Somewhere it didn’t remove container that was created. When you installed again double take it was unable to start it because there was a container already created.
Maybe when you removed double take it removed that container. But I think it didnt.
There is an addon called portainer. You can installed it from repo like
ha addons
With this addon you can destroy your system so be extra careful. The only thing you want to do is to remove unused container. It will show you which container is not used and that is probably container left behind double take. You can remove it, install double take and it should work with out any issue.
This is how it looks when you open containers
The container you want to remove is marked red and probably stopped. But you can check it with the log you posted here.
ok i found the addon and test it.
Thank you for your efforts
it looks like this in the portainer.
nothing to see
Maybe it was removed when you last time removed addon. Try to install double take addon again and run it.
same error as befor
Open portainer and check containers and images.
ok, I can see that you have installed addon Check Home Assistant configuration. This addon is deprecated and if you don’t have really good reason to use it remove it. Maybe this is causing problem maybe not but you probably don’t need it.
the problem is still there.
ok, it’s your system and you have to make decision.
You can remove double take container and double take image with portainer and uninstall double take and install it again.
It shouldn’t break your system but I’m not sure. It’s your decision.
I’ll try it
thank you very much now it works again.
and I’ve learned something new
