Dear Experts,
Using a card to open and close my garage doors. To prevent to do this by acident i put this into a card using the double tap.
Whilte this is working greast with MQTT → and the ESP32 controlers, I faild to steer in the same way a dooropener that is connected to KNX.
How it works with the MQTT <-> ESP32
entity: switch.tor1
tap_action:
action: none
double_tap_action:
action: toggle
type: entity-button
How it does not work with the KNX entity (no measage on the KNX bus):
entity: switch.haustuere
icon: mdi:door
tap_action:
action: none
double_tap_action:
action: toggle
type: entity-button
Is it because of toggle does not work with KNX or do I need to define services…?
I Would appreciate your hints.
Btw: The door opener works via Node Red → KNX works proper. There I send a “true” to open (config on KNX is not the issue).
THX M
