Double Tap Activate scene, but not device
I have recently made the switch from SmartThings to Home Assistant. I’ve migrated all of my devices over and am still working through some kinks. One of them involves a LZW31-SN.
The device’s load controls a single light outside my patio door. I have a scene setup on the switch so that a double tap turns on/off the string lights around my patio. When I was on SmartThings, double tapping the switch to activate the scene ONLY turned on the string lights, the single light remained unchanged. However, now that I’m on Home Assistant and have the same scene control setup there, the behavior is slightly different in that when I double tap, the string lights turn on/off, but the single bulb also turns on/off. I don’t want this to happen.
My automation is fairly straight forward,
When “Central Scene action on Endpoint 0 Scene 001” then do “Turn off Patio Lights”.
Am I missing something?
I found my own answer…
To anyone searching in the future. I had to change parameter 50 in the config, Button Delay Period. I set it at 7 and it’s working now.
