Hi I’m updated haas from 0.7x to 0.91 and encountered same issue as described here:
https://github.com/home-assistant/home-assistant/issues/20371
I can’t load logbook screen, my trace ends with:
"Format should be <domain>.<object_id>").format(entity_id)) homeassistant.exceptions.InvalidEntityFormatError: Invalid entity id encountered: automation.button_long_press__all_lights_off. Format should be <domain>.<object_id>
How do I deal with that?
ps: On top of all my sensors and buttons not triggering automatons anymore. But it seems that I have to fix the logbook screen first.
As said here https://github.com/home-assistant/home-assistant/pull/20367 - I can fix this issue changing IDs with SQL in the database. But I have no idea how to connect there.
