Double View Error
Yesterday i create a new view in my UI. I copy URL and paste it to the settings of the new View. But now the new View is “connected” with another View? Both Views shows the same content and im not able to delete one without to delete the other View too?!
PLS help :frowning:
Bergstern
if you show us what you have done we can help
dont forget to format you code.
i can show u a screenshot.
u can see i have now two Views with the same cards on it. The two Views are coupled i cant change cards without changing the other view.
Because you have called them both “Home” - someone will crrect me if I am wrong, but I think the title needs to be unique.
Yes but why they dont show up as “Home” both. I can see them as Home and Kochen. Its not a big deal i made a backup yesterday too, so i can go back to my old config. But i dont know what i have done wrong that i clone my Views?
I accidentally did this once by naming a new tab exactly the same as an existing one. I think I had to rename both views to something else unique for each (and the same for the URLs) before it rectified. e.g. temporary_1 and temporary_2. Then I changed one of the views back to the original name and the other to what I wanted for the new view.
I’ve just done this myself trying to link a view to some other URL. So if anyone else is having trouble:
You just need to edit the auto generated lovelace.yaml file here:
 /homeassistant/.homeassistant/.storage/lovelace.yaml.
For example delete block near the end of the file:
Snippet
Regards,
J-Cap
