are you wanting to use a single trigger to control both switches at the same time or are you using different triggers to control both lights differently?
You didn’t really give much info as to what you are trying to accomplish for us to answer the question.
are the two triggers supposed to control the lights together at the same time (ie both triggers either turn both lights on or off together)?
or are they supposed to control the lights individually and possibly different depending on the triggers ie one trigger turns on/off one light and the other trigger turns on/off the other light)?
Two lights that are totally independent from each other.
Only thing they have in common is that they share the same wall switch.
It was just a simple question if I had to make an automation for each trigger or maybe it could be done in one automation… you know; because it’s the same wall switch.
If they share the same switch then how would you control them independently?
if you turn on the (single?) switch then the lights should be powered at the same time from the same electrical source (ie the switch).
I’m really not trying to be difficult. I’m just trying to understand the parameters to give you good advice. But what you are saying isn’t making sense to me.
So it is in fact two different switches installed in one gang box and those two switches actually control only one light each.
It’s not ONE switch. It’s TWO. It’s not “the same wall switch”. It’s different wall switches in the same box.
Sounds a little condescending from someone who is asking for help and wasn’t giving valid information when asked for clarification. Words actually have meaning.
But even then it’s still TWO switches and not ONE. It’s just in a different form factor than the standard switches.
