I have run into several significant issues after upgrading from 2023.12.4 to 2024.1.0. Sonoff has documented issues and the new climate features will not work with existing automations. I need to downgrade ASAP. Is there a way to specify a specific version (2023.12.4) with a docker compose pull?
I also needed to downgrade because of the RCT Power Integration.
I edited my docker-compose.yml
homeassistant:
container_name: homeassistant
#image: "ghcr.io/home-assistant/home-assistant:stable" stable is 2024.1..
image: "ghcr.io/home-assistant/home-assistant:2023.12.4"
volumes:
and called
docker-compose pull
docker-compose up -d
This worked for me.
After upgrading to 2024.12.5, I had to downgrade to 2024.4 due to the crappy and (as usual) badly documented incompatible changes to the HA file notification service.
Using docker run
, the following worked for me to downgrade to 2024.4:
replace the stable
tag by 2024.4
, for instance
docker pull ghcr.io/home-assistant/home-assistant:2024.4
docker run -d --name homeassistant --privileged --restart=unless-stopped -e TZ=Europe/Berlin -v ~/Per/3em:/config --network=host ghcr.io/home-assistant/home-assistant:2024.4
