Downgrading versions is a lot faster.
Yes.
Yes.
From what I read I use SSH to downgrade? Is there somewhere where I can find the version numbers and when they were released?
Why are you doing a restore?
I thought you wanted to know how to downgrade?
That way would be faster and will retain all your history. Restoring a backup will lose the history you have accumulated since the last backup.
It’s only an issue if there have been database schema changes. It has been a while since that has occurred.
I was able to downgrade to a previous version. I went back to 2023.3.6 but I do have some errors now. What would cause these errors and how can I fix them?
Update to the latest version -.-
Did you check the logs like the errors tell you to?
Please don’t post pictures of text. Post the text correctly formatted.
From the bit of the errors I can see though it appears you have rolled back about five months. That’s definitely not going to work. Due to database changes.
As I thought…
I installed HA about 9 months ago. How do I get HA back to that exact state? I’m using the Kodi integration and I had it set up so that when I pressed Play, my smart lights turned off, and when I press Pause or Stop, the lights come on. I’m not sure what happened, but Pause stopped registering in the Kodi integration player. With the player pulled up in the HA app on my phone, I press Pause and it doesn’t register. The video pauses but it still says Playing on the Kodi integration. Since it still says Playing, that doesn’t turn the lights on. I’m assuming the Pause function broke in one of the updates? Play and Stop both work fine.
I thought you would be just rolling back one version to check if it was the latest update that was causing issues.
You do not want to restore to a 9 month old state. Bad idea. Do not do it.
Here are the currently open issues for Kodi:
:house_with_garden: Open source home automation that puts local control and privacy first. - Issues · home-assistant/core
If your issue is not listed there and you are sure it is not a configuration issue (check the current documentation) you can open a new issue to get it fixed.
The frustrating part is after I rolled back to an older version of HA, the pause did work for about a half hour and then it just stopped working again. I did nothing to HA in that half hour so I don’t know what changed. I’m wondering if it’s the way Kodi is being discovered on my HTPC. I see that it’s in 2 different sections of HA. In Kodi it’s seen using the ip address and in the other section it says Desktop. When I click the ip address and go to the Player it shows Kodi with a bunch of numbers after it.
Where do I open a new issue?
There is a big green New Issue button on the github page I linked to above.
Well the link brought me to the Home Assistant GitHub page and I wouldn’t think it’s a “home assistant” problem. Isn’t the Kodi integration from a third party? I would think dealing directly with the person who manages it would be the best bet, but what do I know?
The Kodi integration is part of Home Assistant Core, and therefor issues are logged on the Home Assistant GitHub.
The code maintainers for the integration will be notified of your issue
